[Engine] Limp Mode - Low Power
Thanks Given: 1
I have a 2017 850 Enterprise Van.
After discovering a severe windscreen leak after new one fitted I had 2 to 3 inches of water sitting in the floor under the carpet.
One week later I dried it out with engine running for several hours in neutral, heater on max and dehumidifier in the cab running.
I've now noticed it's in limp mode / low power.
No engine management lights or fault codes appear.
Starts up as usual but without driving it, it will only rev lightly, max is just under 3000rpm.
Any thoughts on what could cause this? Would running it on the drive over 7 days for about 4 hours a day cause any issues to look at?
Threads: 3
Thanks Received: 5 in 3 posts
(30-10-2023, 03:39 PM)athlonoc Wrote: I have a 2017 850 Enterprise Van.
Any thoughts on what could cause this? Would running it on the drive over 7 days for about 4 hours a day cause any issues to look at? I've had a get your engine fixed light on for months yet there are no codes. When I took it to the garage they had the Citroen software to delve deeper and it was a low pressure something warning. Happened when I filled the tank. Since they cleared the code it's been fine for a year. Normal readers can't delve into the Citroen software, there are layers that are not accessible to over the counter readers. Take it to a garage with Citroen software and they will be able to read it. Unless someone knows where you can get a reader that will work properly.
Threads: 75
Thanks Given: 223
164
Diagbox. The original Citroen software is the one you need - or a professional scanner like Autel MaxiDiag or Snap-On can work. No cheap ones work.
There will be a code or codes to find, not all faults put the engine management light on. I posted a document showing which faults cause limp mode and to what RPM the limits are set, it's in the how-to section.
• athlonoc
Thanks Given: 1
I took my Van to a local garage and has been connected to a Maxisys 908S scanner for a diagnostics.
The result of the diagnostics showed a BSI fault, and an engine ECU fault x 2 and an Airbag pretensioners ECU fault.
The mechanic cleared all the faults but said there was no link to the low boost/power issue. He suggested I check the air filter in case it was wet but it wasn't.
The ECU faults were U1218:81 & P0493:62
The BSI fault code was F5FF but he said that wasn't a known fault code like the ECU codes.
Other than going to Citroen and printing money for the repairs I'm not sure what direction to go with.
He said you might need to drive it about and hope it clears itself but if a management light on the dashboard lights up then keep it running and bring it back to him!
Any thoughts?
Threads: 46
Thanks Received: 160 in 129 posts
Thanks Given: 34
23
I would suggest this is all because of the large water leak, with water probably getting onto the BSI which controls everything on a Berlingo. Personally, if it were me I would get an independent assessment if the water damage to the system and be going down the legal route of passing the complete cost of any repairs necessary to the company that replaced your windscreen. Not sure if yours does but many car/van insurance policies now have a legal part that covers you for any legal costs?
Hope you manage to get it sorted.
Threads: 75
Thanks Given: 223
164
08-11-2023, 07:28 PM
(This post was last modified: 08-11-2023, 07:32 PM by Sol.)
From the official Citroen system:
INFORMATION : FAULT CODE U1218 (ABS ECU )
Control unit ABS BOSCH 8.1 ontrol unit ABS BOSCH 8.1
Fault code U1218
After sales description of the fault code Fault absence of communication with the built-in systems interface (BSI ) : Data invalid
Description of the diagnostics: The time for recording the fault code is 1000 milliseconds - No transmission of datastreams by the BSI ECU
Context of appearance of the fault code: Ignition on
Conditions of disappearance of the fault: Transmission of datastreams by the BSI ECU
Down-grade modes if fault present - Switching on of the warning light and/or
warning message
Main customer complaints likely - Suspect areas ABS ECU
Threads: 75
Thanks Given: 223
164
(This post was last modified: 08-11-2023, 07:33 PM by Sol.)
INFORMATION : FAULT CODE P0493 (ENGINE MANAGEMENT ECU)
DV6C TURBO DIESEL
Engine ECU CONTINENTAL SID 807 branch 2 engine ECU CONTINENTAL SID 807 branch 2
Fault code P0493
After sales description of the fault code - multi speed fan assembly : Incoherence between the reference value (no control) and the status of the fan assembly
Description of the diagnostics: Incoherence between the reference value (no control) and the status of the fan assembly (For 20 seconds)
Conditions of activation of the diagnostics: engine running
and/or warning message
Main customer complaints likely:
Engine overheating with illumination of the engine coolant temperature indicator light
Absence of automatic stopping of the internal combustion engine (Si
le véhicule est équipé du système Stop and Start)
Suspect areas:
Fan assembly
Fuse
Electrical harnesses
Connectors
Threads: 75
Thanks Given: 223
164
08-11-2023, 07:35 PM
(This post was last modified: 08-11-2023, 08:16 PM by Sol.)
Can't find F5FF, it's not listed. Probably an error of his scan equipment or a "bug" code, there are some like F40 which are software bugs in the ECU and BSI code and are meaningless.
So likelihood is as MS says, you have water in the BSI (very bad) and possibly a faulty cooling system control too (engine ECU). The second one will cause limp mode and it won't go away till the faults are fixed. Or it will come right back. Clearing codes doesn't fix faults unfortunately.
I also hope you get it fixed. Maybe it's a painful one but swapping a BSI is not trivial and needs a specialist in this area to code a new (used) on to work in your car. Most don't come back from this very easily.
Thanks Given: 1
Threads: 75
Thanks Given: 223
164
09-11-2023, 09:47 PM
(This post was last modified: 09-11-2023, 09:49 PM by Sol.)
It's buried behind the glovebox under a mass of wires. Looks like a fusebox, has several levels linked together with micro-pin sockets. Lots of plugs on it.
Wow that's a lot of water to have inside.
One thing after another
Yesterday 05:02 PM
Yesterday 10:41 AM
» Replies: 16
Yesterday 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
