  • 12 Vote(s) - 3.25 Average
fuel cap sealing washer
I am trying to replace the sealing washer that sits underneath the fuel cap on my 2001 berlingo as it has failed the MOT because of this.
I cannot however for the life of me remember whether it was attached to the fuel cap or around the the filler neck as my one has broken and fallen off.
I would be very grateful if anyone can help.
It is a plastic to plastic joint on my diesel partner (96) which looks as if its a new cap needed.
I dont know if petrol is different.
Is it the filler neck that has broken off?
Thank you for the reply.
The fuel cap is fine. I have done some research and I believe it is the gasket around the top of the filler neck that is missing.
The filler neck was broken and I have now replaced it but I didn't realise there should be a gasket around the top that the three screws go through when attaching to the bodywork.
I think this is what the MOT garage have referred to as the sealing washer
Many thanks again for your help.
Ahhh I see what you mean now, you'll have to take off the filler again and put the washer on . did'nt think that would be a MOT failure
Hi, Just for interest, what did it say on the fail certificate for this fault?
:thumbsup:
Hi Rustscrat .
it said fuel cap/sealing device sealing washer missing (7.2.4c) and
fuel cap/sealing device mounting flange/sealing method defective (7.2.4c)
The mounting flange was broken and I have replaced the filler neck but i'm wondering whether there should be a seal around the top of the neck that fits outside the bodywork and the three retaining screws hold it in place
Is this any help? Confusedtudy:
There must of been evidence of liquid coming down the filler neck for them to see this!:eek:
Confusedalut:
Yes I think it must be part number 2 on the diagram.
However that shows the washer as fitting behind the bodywork.
I have ordered that part and i'll see when it arrives.
Thanks for the picture
Hi everyone just to let you all know that I fitted the washer(number 2 on the diagram to the neck of the filler and it has now passed the MOT.
Many Thanks for all the help
(26-04-2012, 11:12 AM)Robbie G Wrote:  Hi everyone just to let you all know that I fitted the washer(number 2 on the diagram to the neck of the filler and it has now passed the MOT.
Excellent, well done.:woop:
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
