Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
I've tried (unsuccessfully) to claim before. It tends to come down to checking the maintenance and inspection records of the council. They are supposed to undertake regular inspections and also to respond to reports of damage within certain time frames. If they fail to do these, then it is possible to get compensation.
I used the website
Pepipoo which explains how to go about it.
Basically, it involved months of letters back and forth, Freedom of Information requests, and in the end I gave up. I have a feeling that Councils are well prepared for these sort of claims, and have a highly sophisticated bullshit and bluster department designed to drive you mad.
The following 1 user says Thank You to Chris for this post:1 user says Thank You to Chris for this post
• j90xxx
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Thats quite a good pothole.
Ive never known anyone to claim from a council regarding potholes.
I DO MISS MY BERLINGO
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
(11-02-2013, 04:24 PM)philip Wrote: Thats quite a good pothole.
Ive lost wheel trims twice in the last 3 months because of our local ones
But the worst damage I had was in a Mk4 Astra when a loose cats eye (STFU taxi) was flicked up by its front whhel and it punched a hole into the rear tyre/rim.Council didnt want to know.
Threads: 67
Thanks Given: 1,045
Can you not lodge a petty courts claim against them for such damage? That would cost them more than a tyre to defend.
Threads: 5
Thanks Received: 9 in 7 posts
Thanks Given: 26
Looks like a crater! Heard on the radio today that a pot hole on the M11 nearly caused a pile up, damaging several vehicles. It's easy to believe that road tax doesn't actually go towards road maintenance at all :brickwall:
Threads: 67
Thanks Given: 1,045
There's a lot of decent holes around here, we had a prolonged wet spell (approx 18 months) and the "pumping" action brought liquefied fine clay up through the crushed road base - now the roads weep clay silt and the whole surface down to coarse rock will shed without much provocation.
Unless your local courts (small claims) specifically exclude such items I would suggest one letter only to the Council, advising that an unsatisfactory settlement would lead to a small claims process without further warning. Provided you claim like-for-like (eg, the replacement cost of installing an equivalent part worn by brand and production year) it's a reasonable claim and the defendant normally has to prove why a reasonable person would make such a claim without genuine grounds.
