Threads: 24
Thanks Received: 6 in 6 posts
Thanks Given: 38
i wanted to replace the rocker cover gasket on my 2001 berlingo van so i bought a 2 gasket kit but only 1 of them fits
the 2nd one is different to the one i need.
I have a 2001 berlingo 1.9 diesel van 1868 cc
the gasket i want to replace looks like it is a flat gasket and the one i received looks like it will fit the lower part of the rocker cover with a groove in it to receive the gasket.
who ever did the last gasket repair used only gasket seal instead of a new gasket so i have nothing to compare it to.
any help will be nice
thanks
The following 1 user says Thank You to petesta for this post:1 user says Thank You to petesta for this post
• Wakou
Threads: 40
Thanks Received: 390 in 347 posts
Thanks Given: 128
29
26-10-2015, 08:12 AM
(This post was last modified: 26-10-2015, 08:12 AM by brodfather11.)
There were some dw8 engines that did not have a gasket , it was a bead of silicon that is used. If your cover does not have a groove for a gasket then its a silicon bead one you have.
There has been questions raised about this before.
Threads: 11
Thanks Received: 8 in 7 posts
Thanks Given: 94
5
I am having the same issue...Im very new to berlingo vans...but with the help of the knowledgable guys on here Im learning quite a bit up to now...I noticed that after cleaning my very dirty engine I have some oil running down the back of the block onto/into the manifold...it seems to be coming from the Rocker cover...on inspecting the front of the block there is a little oil in the glow plug grooves and the silicon seal appears to be cracked in lots of places...now the Haynes manual says it should be a gasket seal ?...it describes "XUD & DW" engines...I have no idea what is in my van..its a 2000.... Mk1 same as yours...Ive not removed the cover yet...so its anyones guesse whether it should be a gasket or not but I shall buy both and let you know what I find,
Regards,
Steve..
Threads: 61
Thanks Received: 697 in 595 posts
Thanks Given: 189
44
Ask at the main dealer about price and availability of the gaskets and exactly what you need, simples.
I did this a couple of years back when I first bought my van and was struggling to determine online exactly what to buy and I'm not dull !
I found for my MK2 DW8 1.9D that only one of the two gaskets were available loose across the counter and I was advised to use the liquid gasket as said above. I was however told / shown on screen that both gaskets were available if I bought an entire engine gasket set - expensive.
Liquid gasket is fine just don't flood everything with it to prevent the stuff getting into the oilways.
Serieal Berlingo owner
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
30-10-2015, 04:02 PM
(This post was last modified: 30-10-2015, 04:02 PM by Col.)
You guys thinking of using *liquid gasket*
I can highly recommend Vauxhall sealant Pt No: V0093165267 available from your local G.M. dealer.
I have tried all sorts and this is one of the best
