Threads: 7
Thanks Received: 1 in 1 posts
Thanks Given: 6
05-02-2011, 12:34 PM
Citroen Berligo Multispace 2004
Has anyone changed a back door handle..We can open it from the inside but
it seems that the outside one is not working...It is loose.
Is it easy to change?
Any help appreciated...
Threads: 40
Thanks Given: 82
6
I've not done it on a Berlingo, but done similar on a BX. If the handle isn't doing anything it could just mean that the wire that it pulls to open the door has become disconnected, it could just be a matter of reconnecting it.
I had one door on my BX that would not central lock and it was this causing it.
Threads: 7
Thanks Given: 6
06-02-2011, 10:40 PM
Hi,
It's hinged handle...
thanks.
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
Hi
Call me daft if I haven't read this correctly but I assume when you say back door you mean rear sliding doors?
If it is a rear sliding door I would put my money on the metal pin that runs through the handle connecting to the linkage has snapped. It's a relatively common issue and easy to fix, but you will need the correct part. A bodge is not really an option.
Contact me if this sounds like your fault and I'll run through it with you.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 7
Thanks Given: 6
Hi Divingscubaboy,
Yes I meant the rear door, thanks for your reply... When I try to fix I will probably get in touch with you for some advice, thanks.
Threads: 13
Thanks Given: 7
Forgot to say does the door handle flap around wildly i.e. With no resistance? You will probably find you'll need to get the part from a breakers around £35 as my local stealer wanted around £180! You can't buy the offending item separately.
alut:
Threads: 0
Hi,
Got same problem, did you find the metal replacement pin?
I have found one on eBay, however its Poland and am warry of using paypal to purchase it.
Cheers,
Bod
Threads: 13
Thanks Given: 7
Ive just ordered a pin from Poland, well 2 actually. Thought I'd get a spare. I'll let you know how succesful it is. For those who haven't changed one yet i'll try and put a how to on here.
alut:
