Juddering
Hi all. I have a berlingo van 1.6hdi on 2012 plate with 40 k..just recently diagnosed with worn clutch release bearing but told not to do until time for new clutch..
Am now experiencing a judder when reversing up slight gradient on drive way and when pulling away in first and second gears however it's intermittent but the 1st , 2nd gear issue is worse after a long drive.. All of this has only started though since I had new brake pads and tyres fitted on front only... Any suggestions are welcome ...cheers in advance
Check engine mountings.Contaminated or warped clutch plate.It may sound silly but check wheel bolt security.
(03-04-2015, 07:11 PM)ron Wrote:  Check engine mountings.Contaminated or warped clutch plate.It may sound silly but check wheel bolt security.
I did wonder engine mountings which I guess are easier to rule out than the contamination! Cheers, will look into that
Make sure the brake pad's are fitted properly and are not loose there may be oil getting on the clutch plate i think it would be better to change the clutch and bearing sooner than later it could end up costing you a lot more  Sad
[-] The following 1 user says Thank You to Jed Clampit for this post:
  • Scooby jay
Cheers jed, think I may stop off at main dealers during week to get them to check brakes as it has only started since that day..does 40 k on a clutch seem a bit low though?
The thing is if your not the first owner how much time did they sit in traffic with their foot on the clutch peddle let the dealer check it through first and we will know where we are coming from
True indeed and think the good old days where people buy a new vehicle and break them in gently are a thing of the past ..always seems to be brand new motors overtaking me!
Today 04:46 PM
» Replies: 18
Column Universal Joint
Last Post: pondweed
Today 01:00 PM
Touchscreen Version
Last Post: sswindon
Today 12:03 PM
Internal roof bars
Last Post: Iank
Today 12:01 PM
» Replies: 24
Last Post: Iank
Today 11:57 AM
Today 11:17 AM
Today 10:44 AM
Today 10:37 AM
Yesterday 07:07 PM
Yesterday 07:04 PM
