bottom tensioner
Shocked
Hi ive been told a whining noise which sounds like ive got a 50cc under the bonnet is the lower fan belt tensioner and is a common fault . Can anyone confirm this? Doesnt whine when idling only when revving up. If it is the tensioner can someeone send me a link on where i can buy one and what exactly this tensioner is called / looks like. Thanks
I also have ac due to the van being a freezer van
(11-05-2015, 08:29 AM)johntychwith Wrote:  I also have ac due to the van being a freezer van
what engine  is it.?
The tensioners when they start to go can sound like you describe.
1.9 d non turbo
(11-05-2015, 06:04 PM)johntychwith Wrote:  1.9 d non turbo
there are two 1.9d engines , what year is it and is it a XUD or DW8 engine
The XUD has a manually adjusted one and the dw8 has a automatic adjuster
1999 x reg 1.9d
Try this one. it may fit but because of your AC not 100% sure.
http://www.ebay.co.uk/itm/Gates-Driveali...4d3195e2dd
You can see your one if you take off the cover at the pulley end of the engine , its under the o/s wing and has about 4/5 plastic screws/studs. You can then compare , if in doubt take it off and try a local motor factors.
Or it may be the alternator/ ac compressor /power steering pump making the noise but the tensioners are normally guilty.
Yesterday 04:46 PM
» Replies: 18
Column Universal Joint
Last Post: pondweed
Yesterday 01:00 PM
Touchscreen Version
Last Post: sswindon
Yesterday 12:03 PM
Internal roof bars
Last Post: Iank
Yesterday 12:01 PM
» Replies: 24
Last Post: Iank
Yesterday 11:57 AM
Yesterday 11:17 AM
Yesterday 10:44 AM
Yesterday 10:37 AM
27-04-2024 07:07 PM
27-04-2024 07:04 PM
