hi all,
i have a 2003/4 berlingo 2.0 hdi and a while ago i noticed a whirring noise that occurs after engine is switched off, sounds like a small electric motor or pump and it lasts a few mins before fading.
it continues even if battery disconnected.
i noticed it again today after it wouldn't start after i changed fuel filter.
my berlingo does not have fuel pump in tank as it has the pressure bulb near filter.
any ideas what it is?
thanks.
steve g.
Thanks Given: 192
45
He put this question in the wrong section ( M49 ) before and has now started a new topic in the correct area in an attempt to get a better response, hopefully.
Anyway, if it happens with the battery disconnected then it cannot be a motor or other such item. In the previous posting I suggested it might be the cooling system depressurising.
cheers geoff! i hear what you are saying, but it definitely 'wirrs' like something spinning down.
steve.
Threads: 15
Thanks Received: 26 in 17 posts
Thanks Given: 25
Location: Blairgowrie, Perth And Kinross, United Kingdom
As I posted in the other thread also, it would appear to be the brake servo making the noise on my M59. Stops after a few pumps of the pedal.
Threads: 12
Thanks Received: 3 in 3 posts
Same with mine, I just guessed it was the ecu shutting down' certainly causing no trouble.
surely the ecu has no moving parts? and it wouldn't continue if battery disconnected?
