M59 DV6B Fuses & Wiring Diagrams - enjoy
Fuse layouts at last for the M59 with description. Next post will Including wiring diagrams for injection, ignition & preheat and starting system, zipped in groups of 3 bitmaps per zip file.
This is for DV6B (1.6 HDi)
Attached Files Thumbnail(s)
.docx   M59.docx (Size: 448.51 KB / Downloads: 312)
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
[-] The following 4 users say Thank You to Sol for this post:
  • Gryffindor, IHateMyDadsM59Berlingo, Jmarques, mrak
The rest in zip form due to size and detail...
And the list of item numbers so you can identify what is what on the diagrams...
.zip   M59_1.zip (Size: 379.96 KB / Downloads: 401)
.zip   M59_2.zip (Size: 567.77 KB / Downloads: 271)
.zip   M59_3.zip (Size: 349.55 KB / Downloads: 258)
.pdf   Citroen Components.PDF (Size: 153.2 KB / Downloads: 32)
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
[-] The following 3 users say Thank You to Sol for this post:
  • Gryffindor, IHateMyDadsM59Berlingo, patholio
(15-07-2018, 09:40 AM)Zion Wrote:  The rest in zip form due to size and detail...
Thanks for the diagrams my van is the same I think!, do you have a list of the components that are on the diagrams as I see a lot of numbers but no item to what they are, my chassis number is VF7GB9HWC94308956.
Reply from Sol: See second post
I'd need the engine code mate, and RPO number from the door sticker. I can get the engine code from your vin number, I'll take a look and get back with what I can find. What issue are you trying to fix?
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
Hi Thanks for getting back to me, issue i am fixing is the wiring loom has damage due to a crash on passenger side wing, which i have now repaired loom as I am an Auto electrician, van starts and runs but will not rev up not seeing any data on throttle pedal which fault code tells me it has no voltage.. I have metered wires out and all good but white wire 731 off pedal looks like it goes to ECU on your diagram, but on another it goes to fuse box, so not sure which diagram is correct or if ECU is damaged due to crash the van had with all the wiring shorting out
Hi there, yeah the full pedal wiring goes to the ecu which is numbered 1320 on the diagrams, the pedal being numbered 1261. Multi way cable 10pr is the harness section its in. The wires are shown in drawing injection 1. These are from Citroën Servicebox so they're accurate. The list of items are not that great in Servicebox and the van data is scant in it too. That's as much as I could get.
The other drawings show the same circuit in various detail. I'll see what else I can find. Is the pedal being powered?
There are fuses under the top tray too, it's riveted in place but you can remove it to get to them.
I've seen sensors down from harness damage that then blew a fuse, so nothing worked even after a wiring repair.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
(05-08-2018, 09:28 PM)Zion Wrote:  Hi there, yeah the full pedal wiring goes to the ecu which is numbered 1320 on the diagrams, the pedal being numbered 1261. Multi way cable 10pr is the harness section its in. The wires are shown in drawing injection 1. These are from Citroën Servicebox so they're accurate. The list of items are not that great in Servicebox and the van data is scant in it too. That's as much as I could get.
All fuses are good it starts and runs but will not rev up. no reference voltage at pedal so I have sent ECU off for a test, many thanks
OK mate, hope you get it resolved. The fuses I mentioned are hidden under the top layer of the fuse box, and can't be seen unless you drill the rivets out and pull the top layer out. The ecu has several different sensor power circuits supplied by different fuses.
I'm a spark too and you know a damaged loom will either have blown a fuse or worse still, taken a solid state output down on the ecu. Best of luck with it mate  Smile
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
(06-08-2018, 09:03 PM)Zion Wrote:  OK mate, hope you get it resolved. The fuses I mentioned are hidden under the top layer of the fuse box, and can't be seen unless you drill the rivets out and pull the top layer out. The ecu has several different sensor power circuits supplied by different fuses.
Hi Thanks for getting back in touch, there were several fuses blown due to the wiring all been shorted, replaced them and they have not blown since, will let you know how things go this week.
Hi body
I wonder if you can help me getting the wiring diagram and anything else you can provide for my van, its M59 1.4L TU3JP and VIN is VF3GBKFWC9N022969.
I'm having a problem with the Air cond. and I believe it has something to do with BSI, I need the wiring diagram so i can track the problem.
thanks
P1338 Fault code.
Last Post: ilikesprouts
Today 07:36 PM
» Replies: 20
Seat cover zip
Today 07:32 PM
More battery
Today 06:05 PM
Steering Wheel
Last Post: limey2000
Today 04:30 PM
Last Post: uhurusurfa
Today 03:21 PM
FREE B9 rear parcel shelf
Last Post: Sparky58
Today 01:27 PM
Last Post: jj9
Today 08:45 AM
Hi to all
Last Post: Oligomania
Today 08:03 AM
Today 07:17 AM
» Replies: 20
Last Post: Blakey
Yesterday 05:13 PM
