  • 1 Vote(s) - 1 Average
2008 1.6 hdi lack of power ?
Hi, this is my first post. I have a 2008 1.6 hdi 166k.
Had it a couple of months and it's been ok and very nippy! Recently the power seems to have gone, there's no oomph in it anymore. Before I used to put accelerator down and it was very perky, now very little happens.
Any common probs that can cause this, feels like something blocking it from going!
It could be that your MAF has failed, but I'd expect the EML & 'Anti Pollution Fault' to be displayed. It's quite easy to disconnect the MAF and see if it makes a difference but it's probably best to get an OBD code reader, they're cheap enough on flebay.
[-] The following 1 user says Thank You to cancunia for this post:
  • Andynumpty
yes a bluetooth obd is very useful for diagnosis, you can check if the turbo is boosting too
So if I disconnect the MAF and it's exactly the same will that point to the fault or should it run better?
Think I have a Bluetooth OBD reader, will that test the turbo?
(05-10-2018, 07:02 AM)Andynumpty Wrote:  Think I have a Bluetooth OBD reader, will that test the turbo?
the torque app should link to the map sensor and display the boost reading
[-] The following 1 user says Thank You to frank for this post:
  • Andynumpty
(05-10-2018, 07:02 AM)Andynumpty Wrote:  So if I disconnect the MAF and it's exactly the same will that point to the fault or should it run better?
Disconnecting the MAF should put the ECU into a default fuel map, engines often run better without a MAF, as opposed to with a faulty MAF.
Download the Torque app, it will allow you to see the boost, fuel pressure etc in real time with the engine running. You can also check for fault codes.
  • Andynumpty
A standard unmodified 1.6 HDI 16v should make a bar of boost I think, according to the OBD thingy I've used. Does your speedo work correctly by the way?
Hi, ive disconnected the airflow sensor and tbh it does run slightly better at low revs but still missing the acceleration when I floor the accelerator, like it did before.
For some reason the bluetooth OBD tool I have wont connect to the ECU but it works fine in my Focus.
Any ideas ?
(06-10-2018, 12:07 PM)Andynumpty Wrote:  For some reason the bluetooth OBD tool I have wont connect to the ECU but it works fine in my Focus.
Any ideas ?
What OBD tool do you have? Not all of them support all of the OBD protocols.
The table at the bottom of the page shows which protocols are supported by the Berlingo
http://pinoutguide.com/CarElectronics/ci...nout.shtml
mine,s a black xtrons one, £6 on ebay
and my boost often registers 1.25 bar (depending what gear or rpm) but then settles at about .9bar
Today 04:46 PM
» Replies: 18
Column Universal Joint
Last Post: pondweed
Today 01:00 PM
Touchscreen Version
Last Post: sswindon
Today 12:03 PM
Internal roof bars
Last Post: Iank
Today 12:01 PM
» Replies: 24
Last Post: Iank
Today 11:57 AM
Today 11:17 AM
Today 10:44 AM
Today 10:37 AM
Yesterday 07:07 PM
Yesterday 07:04 PM
