Thanks Given: 1
The TB motor is not a stepper motor. It only got two pins and opens the valve fully with applied voltage. The motor axle got a pinion which rotates a large gear connected to the valve axle. The valve is spring loaded so it closes after removing the voltage.
Thanks Given: 1
I'm asking around if I can borrow a Lexia locally.
Thanks Given: 1
09-12-2015, 07:55 AM
(This post was last modified: 09-12-2015, 08:22 AM by plazma.)
I checked the code with RPO decoder. It looks like the code have to begin with 10... to get the correct manufacturing date.
So the code is probably 10x2x. Do I need to enter five or four numbers (0x2x) to the Diagbox SW?
Thanks Given: 1
I got it working. The cable had to be disconnected and reconnected before choosing Lexia in the SW. Rpo code did not matter.
Where do I find the readings from the throttle valve position sensor?
