lightning strikes, Berlingo
So I was driving a chum of mine a while ago through a thunderstorm and he said a car is the safest place to be in a storm as the metal cage protects anyone inside.
ok, I sad, but the modutop roof on this one is plastic. He went a bit quiet.
I think it's called a Faraday cage?I would have thought the roof frame would be enough?
(20-01-2016, 07:33 PM)ron Wrote:  I think it's called a Faraday cage?I would have thought the roof frame would be enough?
Indeed
Is it not the tyre's that stop the lightening  going to earth and not using you and the car as a conductor and the smell of burnt skin get that out of your carpet's.  Sad
It's the same principal as an aeroplane. They get hit about once a year. The current flows around the outside as metal conducts best.
[Image: 300611gentesla7_170oh9n-170oh9p.jpg]
Out of all the french car's nemesis you had to struck on.......ELECTRICITY
You are lucky it didn't stop and die there and then. Mine just developed a backfire and loss of power for no reason. Knowing french it will be coilpack or spark plugs AGAIN! fak
[-] The following 1 user says Thank You to Kokain for this post:
  • ron
rubber tyres are black cos they put carbon in the mix, carbon is a god conductor of electricity ,  lightening will go straight through the tyres to ground,  wet tyres even better,    Smile
btw they put carbon in to stop uv light penetrating into the rubber and destroying it.
[-] The following 1 user says Thank You to ricc for this post:
  • ron
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
