Threads: 35
Thanks Received: 2 in 2 posts
Thanks Given: 28
Is the comms unit the same for the airbag warning light?
Threads: 36
Thanks Received: 88 in 85 posts
Thanks Given: 1
4
F you have an airbag warning light problem on a M59 it is most likely one of the 2 connections under the driver's seat. They are rubbish and a known problem
Peter
Threads: 59
Thanks Received: 253 in 215 posts
Thanks Given: 228
29
It could also be a flimsy earth point behind the airbag. There are a few posts on the forum how to secure it properly.
Threads: 3
Thanks Given: 2
I have a 2003 1.9D berlingo on and off airbag light tried a bypass resistor to find a dead short inside the ACU connector, these connectors are rubbish it takes a lot of fiddling to separate, always dis connect battery and key in pocket avoid accidentally energizing your airbag as a punch can kill if not sat in seat with headrest on, anyone had the same problem?.??
Threads: 35
Thanks Given: 28
the thing that people are telling me I already know
Threads: 75
Thanks Received: 1,281 in 1,134 posts
Thanks Given: 223
162
A bit more detail on the question might help then.
If you post a one-line vague question (which comms unit do you mean for example) then people might be able to answer in a more specific way. What is the actual problem and what have you tried, etc.
