Strange dashs lights issue
Threads: 2
Hi,
I have tried to search for the answer to this issue but have failed so far.
I have an '04 1.9 enterprise and have some dash lights such as engine,abs and fog that appear faintly when handbrake is on, or indicators in use. I thought that other dash lights were leaking light into these making them light up, but some are the other side of the panel so this can't be the case.
Any ideas ?
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Maybe it like the film Close encounters the van is trying to communicate with you?
I DO MISS MY BERLINGO
Threads: 2
Hehe yeh ! Its most bizarre
Threads: 63
Thanks Given: 410
Is it the "Starship" Enterprise model you have got ???
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
Sounds like an earthing problem somewhere but it could possibly be a nightmare to find unless you can get hold of some info for the wiring
Threads: 15
Thanks Received: 26 in 17 posts
Thanks Given: 25
Location: Blairgowrie, Perth And Kinross, United Kingdom
I have a 2006 1.9 Enterprise and it does the same. Put on the indicators and various dash lights come on in unison to the indicator. Different lights depending on whether it is left or right indicator. Lights dont appear at full brightness and not really noticable during the day. If the side or main lights are on then a different combination of dash lights appears again when using the indicators. Has been doing this for about 4 years now I think and I have become used to it. Dash lights coming on are ABS, watertrap light, fog light, engine management. Might need to get it checked before MOT in November as warning lights on dash now included and certain ones being on means an instant fail.
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
07-03-2012, 07:08 PM
(This post was last modified: 07-03-2012, 07:26 PM by Rustscrat.)
Hi, Check these earths -
MC42, located under the centre console next to the air bag ECU.(Speedo cluster main earth).
MC11,MC13, located on nearside inner wing near headlamp,(Bsf & Bsi earths).
Also check your main battery earth to the chassis & engine.
Let us know what the results are. :thumbsup:
(07-03-2012, 07:04 PM)tanto Wrote: I have a 2006 1.9 Enterprise and it does the same. Put on the indicators and various dash lights come on in unison to the indicator. Different lights depending on whether it is left or right indicator. Lights dont appear at full brightness and not really noticable during the day. If the side or main lights are on then a different combination of dash lights appears again when using the indicators. Has been doing this for about 4 years now I think and I have become used to it. Dash lights coming on are ABS, watertrap light, fog light, engine management. Might need to get it checked before MOT in November as warning lights on dash now included and certain ones being on means an instant fail.
Hi, put your hazards on and then get someone to press the brake pedal.
Have a look at your rear lights, are they dimming or doing strange things?? If so classic case of bad earths.  alut:
2006 2.0hdi 600 with bench seat.
Threads: 15
Thanks Given: 25
(This post was last modified: 07-03-2012, 09:12 PM by tanto.)
(07-03-2012, 07:08 PM)Rustscrat Wrote: Hi, Check these earths -
Cheers Rustscrat, will check out the earths at the weekend. Have to get the wife to help check the rear lights when she gets home later.
Threads: 2
Thanks for this... I'll check soon, getting timing belt done tomorrow first off.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
