  • 5 Vote(s) - 2.8 Average
Door locks interchangeable?
Hi, the drivers side door lock is really touchy and some days take 10-15 attempts to unlock (non central locking btw) and some days i can open it by just putting the tip of the key in and turning. meanwhile the passenger side is spot on and opens perfect every time... so is it possible to just swap lock cylinders from ns to os or are they different?
cheers for any help guys
The cylinders interchange; you need to remove the circlip holding the small actuation lever on the butt of each cylinder and change these to the other side.
Removal of the cylinder is effected through the oblong, plastic covered access port in the door's side - no need to remove the door card or membrane unless you accidentally drop the retainer fork into the door shell.
[-] The following 2 users say Thank You to addo for this post:
  • CandR, kungfu
Thank you! job done in 5 minutes!
[-] The following 1 user says Thank You to kungfu for this post:
  • Ol'Jeffers
Rattling calipers
Today 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
