hi I have a x reg berlingo van with a 1.9 diesel engine the clutch bearing gave up and the fork was stuck so fitted new clutch kit and fork kit lasted three days and it's done the same.Only looked like a plastic bearing in the kit any advice appreciated
Did you use a good branded clutch & fork?
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• Dotcomdaz
Threads: 40
Thanks Received: 390 in 347 posts
Thanks Given: 128
29
Hi ,
I've seen two examples where the shaft that carries the clutch release bearing seizing up in the bush at the bottom of the bell housing, usually grit and dirt getting in through the rubber plug, it stops the release bearing from clearing the clutch pressure plate properly and wearing the fingers away and jamming into the hole it had made. One of the two needed a complete clutch assy. and the other had a clutch pedal which would not return. It was saved by a timely injection of oil into the bush and is still running
Sorted clutch bearing failed cheep valeo one eurocarparts would only swap like for like so got a Bosch metal one
Thanks Received: 697 in 595 posts
Thanks Given: 187
44
04-03-2015, 09:08 PM
(This post was last modified: 04-03-2015, 09:11 PM by geoff.)
Same here ..... anyway just a reminder for all those with the plastic bush set up to lube it from time to time with oil. Don't worry about clutch contamination as this won't happen, what will happen is the oil will eventually reach the bottom bush as well which is good news.
