Threads: 0
Definitely having a go once I can open up this PDF
Threads: 0
Hi just joined forum and wanting to download rear shoe fitting pdf
Threads: 0
Hi all, also looking to do this on a friends Berlingo. Mostly worked on disc brakes tho. Is it always necessary to replace wheel cylinder or only when leaking? Also when you back off the adjuster thro the inspection hole is it obvious which way to turn it to back off?
Thanks for answers in advance. Also how do I download that pdf as having no joy?
Kind regards,
Matt
