temp gauge
Threads: 2
Thanks Given: 2
temprature gauge not working
Thanks Received: 531 in 479 posts
Thanks Given: 188
23
Hi there welcome to the forum, it would help if you could give more information like make, model ,year and engine in your vehicle.
Are we there yet?????
• polar
Threads: 29
Thanks Received: 375 in 329 posts
Thanks Given: 67
20
Is there any coolant in the engine ?
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
(04-03-2020, 09:16 PM)dave g Wrote: temprature gauge not working
Hi and welcome to the forum
Cant answer your questions because i havent a clue what type of berlingo you have.
Try saying hi and introducing yourself you may find people will want to help you if you are polite.
Threads: 2
Thanks Given: 2
hi thanks for that,
hello my name is dave i have been on this form for about six years and find it very useful
my belingo is a 600 hdi 07 van,
temp gauge not working stop light comes on the dash when you turn on ignition but goes out when you start engine, could it be the ecu
Threads: 9
Thanks Given: 316
15
(05-03-2020, 10:22 AM)dave g Wrote: hi thanks for that,
Hi dave i suspect your van is the 2.0hdi? If it is the temperature senders are known to play up - its located in the thermostat housing.
I doubt it is the ecu, and if it was the BSI you would get other faults too - you could try a BSI reset. Just google the procedure it will take about 10 minutes.
• dave g
Threads: 2
Thanks Given: 2
(05-03-2020, 10:04 PM)polar Wrote: (05-03-2020, 10:22 AM)dave g Wrote: hi thanks for that,
hi polar thanks for the reply, registration doc says it is a 600 hdi enter 92 whatever that means, but the cylinder capacity is 1560 cc but i will have a look at resetting bsi.
Threads: 9
Thanks Given: 316
15
(05-03-2020, 10:24 PM)dave g Wrote: (05-03-2020, 10:04 PM)polar Wrote: (05-03-2020, 10:22 AM)dave g Wrote: hi thanks for that,
Okay early 1.6hdi - there are two senders in the same location - thermostat housing, you could try checking the connections for corrosion and short each plug to ground, if the gauge goes up then its the sender. Basically a temperature gauge is just showing a voltage and the sender has a semiconductor material inside that passes more voltage as it heats up - if you know what i mean.
• dave g
Threads: 2
Thanks Given: 2
thanks polar, if i reset bsi like you said to try will i lose radio code
Thanks Given: 188
23
No the radio code is stored in the ecu you should be fine.
Hi
Today 03:52 PM
Air filter box
Last Post: NANO_Vigo
Today 12:51 PM
ABS light, No Speedo, Loss of Power. Can anyone ...
Today 12:47 PM
Haynes K9 online manual
Today 12:40 PM
The creation of my personal solo-travellor.
Last Post: EM58
Yesterday 09:48 PM
» Replies: 22
Engine occasional hiccup, engine management flas...
Last Post: OMG
Yesterday 08:14 PM
2009 Turbo Failure.
Last Post: OMG
Yesterday 08:10 PM
Trailer Electrics - Fuses (2019 Van)
Last Post: Romahomepete
Yesterday 05:48 PM
2012 B9 Starter Motor replacement.
Last Post: Ron_man
Yesterday 04:45 PM
Locked car while driving.
Last Post: Anyinfo
Yesterday 04:18 PM
