Threads: 22
Thanks Received: 13 in 11 posts
Thanks Given: 24
Hello all,
does anyone know if the rear axle from a 2018 model would fit a first gen 2002 model ?
Any help appreciated.
Mk1, 1.9D, Admiral Blue, 51 Plate.
Threads: 8
Thanks Received: 493 in 443 posts
Thanks Given: 298
29
No.
Look up M49 / M59 rear axle to get an idea of what they look like, then look up a B9 rear axle and you will see that the setup is completely different.
• THE BADGE
Threads: 22
Thanks Given: 24
Many thanks JJ9
Threads: 6
Thanks Received: 23 in 21 posts
not totally sure but somethings tellin me that peugeot 306 axle is the same as m49 berlingo
Threads: 36
Thanks Received: 90 in 87 posts
Thanks Given: 1
4
It is confusing to talk about Mk1, Mk2 etc.
Citroen Designations are M49, M59, B9 and K9
M49 and M59 share the same bodyshell and have a torsion bar rear axle.
M9 and K9 are similar to each othere in looks but there are major body differences and they both have coils prung rear suspension
Peter
Threads: 36
Thanks Given: 1
4
A quick google search brought up 3 companies that supply reconditioned avles for the M49/M59
Peter
Threads: 17
Thanks Received: 6 in 6 posts
Thanks Given: 64
03-04-2022, 05:04 PM
(This post was last modified: 03-04-2022, 05:09 PM by Blackshuck.)
I've got an '04 2.0hdi M59 Berlingo van based Romahome camper - got a recon 800kg chassis axle from imaxle - fitted with no probs
