Help needed Code C1381
Had this code since Sept had 2 sencers changed keep going to garage but all he says is till it comes on when you get here I cannot help.
Hi all I am getting Berlingo Mulitspace 16 hdi
I keep getting code c1381 but says Temp circulating pump.
I know its ABS, but could be 3 things.
Has any one got better idea, start car up pull off may not come on for upto 10 minutes. Switch off goes when starting back up, before looking at repairing upto all 3 things, cost about £2,000 if they do not hit the problem till the third attempt.
Any help I would be thankful for.
Your Reach is further than your Grasp
I had a quick Google, most of the results seem to be Peugeot but that's not too far off from Citroen.
I've not looked at this video all the way through..
https://www.youtube.com/watch?v=DA45607U4-w
https://www.google.com/search?q=berlingo...CA0&uact=5
Can you post numbers from ABS unit.
Best regards,
brajomobil
(23-03-2021, 01:58 PM)brajomobil Wrote:  Can you post numbers from ABS unit.
Best regards,
brajomobil
No idea where that is or code, unlss I go to the garage, Sorry.
Well booked it in another garage, told them code and to check every thing, asked for a price, like watching Benny Hill, first coughed then spluttered, answering not to shore all depends on whats wrong. I know that one, but it was nice to see him wrigglefor a minute.  Got to be done see what he says, 61 plate, so near top price if top bill, but one thing should not go again for a while.
But it is a Berlingo anything is possible.
Thanks to those who gave me ideas to pass on.
Could be a seized ABS pump.
  • jtr rhyl
Just phoned garage up, they say its the pump, dealer £800 or recon £400, just hope it does it.
Tyre pressure monitor
Last Post: Blakey
Today 05:13 PM
Berlingo 2007 1.6 hdi - intermittent sticky acce...
Last Post: Dwight07
Today 09:23 AM
brake master cylinder
Last Post: BigVtwin996
Today 08:45 AM
Can you clamp the rubber brake hose?
Last Post: flanagaj
Today 07:06 AM
Are brake pistons / seals a common size?
Last Post: flanagaj
Yesterday 08:23 PM
Brake lights in spite of changed BSI - need advi...
Yesterday 04:55 PM
Kjøleviften går ikke oransje trekant kommer opp ...
Yesterday 04:36 PM
Front seat removal ..legal ?
Last Post: Bluebottle
Yesterday 01:02 PM
ABS warning light - possible broken cable???
Last Post: Artymorty
Yesterday 06:42 AM
» Replies: 16
Van front seat conversion to 3 seats
Last Post: Golfbuggy
30-04-2024 03:41 PM
