Threads: 2
Hi
I'm thinking of buying a HDI 110 XTR, the tyres are listed as 215/55/16, can anyone tell me what the remaining letters are (H V W 94 97 etc)
I also tow an Eriba caravan, max gross weight 1300kilos, This is 91% of the cars weight, does anyone tow a similar weight caravan ? how does the car perform with it on the back ? hills ? stability ? anything else
Many thanks
Frank
Thanks Received: 213 in 171 posts
Thanks Given: 44
5
The remaining numbers(load index) & letter(speed rating) for XTR are 93v this means each tyre can take a max load 650kg at max speed 149mph. I used to tow an Eriba Pan with mine about 850kg all up with no problem. I take it you have a Troll? Eribas are very stable tow due to aerodynamic shape. The Pan used to tow like it wern't there.
Threads: 5
Thanks Received: 2 in 2 posts
Regarding towing a caravan with the berlingo multispace HDI 110 XTR , I HAVE HAD A 110XTR SINCE NOV 2010. LAST YEAR MY WIFE & ITOWED OUR COMPASS RALLYE GTE 510/5 FROM HOLYHEAD TO CAMBRIDGE WITH O PROBLEMS THE CARAVAN WEIGHT IS 1300KG PLENTY OF POWER SAT AT 60MPH ON ALL THE MOTORWAYS WE ACTUALLY PUT OUR AWNING & WINDBREAK ACROSS THE BACK SEAT ALONG WITH THE CRATES THAT WE STORED ALL OUR CLOTHING IN WE MUST HAVE DONE OVER A THOUSAND MILES LAST SUMMER WITH THE CARAVAN DEFINITELY GO FOR THE 110XTR YOU SHOULD ENJOY TOWING WITH IT
Threads: 2
Many thanks for the above information
Frank
