BSI Reset Procedure
BSI Reset.
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
[-] The following 6 users say Thank You to Sol for this post:
  • Bilbo, deejay_xb, jemselectrical, Pedronicus, Stoots1975, Zorgglub29
If this does not work and you still have a problem with odd behaviour of the windows, central locking, lights, wipers or suchlike, you can perform a hard reboot of the BSI by locating and pulling the SH-HS Shunt-link (looks like a fuse but is green & white with SH-HS stamped on it) then after a minute, reinsert it.
The battery should remain connected for this type of reset.
The link mentioned is on the BSI front panel, which for the B9 vehicle is behind the glovebox and on the M59 is under the steering wheel behind the lower dash panel.
Ensure you put the shunt link (SH-HS link) back in the correct position, not in the "PARK" position, or the radio, interior lights, central locking etc will appear to be malfunctioning...
  • jemselectrical
Mirrorlink and Android Auto issues
Last Post: djib1946
Today 10:21 AM
Advice on Fuel Pump Please
Last Post: magwych
Today 07:40 AM
Hello
Last Post: Sjbsjb3838
Today 04:22 AM
Hello
Last Post: Ringo2024
Yesterday 07:47 PM
Airbag warning light
Last Post: Squad
Yesterday 06:12 PM
The creation of my personal solo-travellor.
Yesterday 05:39 PM
» Replies: 16
Adding heated seats to a k9
Yesterday 05:35 PM
Door Sticker Part number
Last Post: ComboLifer
Yesterday 04:51 PM
2012 MULTISPACE WINDOW REGULATOR FAILURE
Last Post: lauramayer14
Yesterday 04:22 PM
wiper motor replacement
Last Post: mickrochip
Yesterday 02:20 PM
