  • 5 Vote(s) - 2.6 Average
Mud Flaps
Has any one put on mud flaps on their vehicle , is it an easy job .
I've bought a set but still have not installed them (crawling around on a freezing garage floor is not appealing - maybe in the spring). From the instructions it looks pretty simple. Bore a couple of holes and screw them on. I'll have the wheels off to put on summer tyres in the spring.
It's as easy as the instructions imply - fitted rear mudflaps earlier this year. C'est un doddle.
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Quote:C'est un doddle
Merci
If you buy the official Citroen items you don't need to drill. My Mk2 ones are held with the push fitting for the under wing plastic and a clamp on the wing edge and sill lip.
(10-12-2013, 05:18 PM)ffrenchie Wrote:  If you buy the official Citroen items you don't need to drill. My Mk2 ones are held with the push fitting for the under wing plastic and a clamp on the wing edge and sill lip.
Any pics of these flaps fitted mate? Confusedtudy:
http://www.berlingoforum.co.uk/attachment.php?aid=1191
Wait... are we speaking of mk2 (2002-2008) or mk2 (2008-) ? Wink
2008- would surely be a Mk.3 N'est pas?
Fitted genuine rear mud flaps to my xtr,just remove the wheels follow instructions and take your time and it is straight forward.
Genuine mud flaps don't fit the front of xtr's though because of the side mouldings.
Thread about it with pictures here earlier when I first got the car.
Can you clamp the rubber brake hose?
Last Post: flanagaj
Today 08:25 PM
Are brake pistons / seals a common size?
Last Post: flanagaj
Today 08:23 PM
brake master cylinder
Last Post: BigVtwin996
Today 06:52 PM
Brake lights in spite of changed BSI - need advi...
Today 04:55 PM
Kjøleviften går ikke oransje trekant kommer opp ...
Today 04:36 PM
Front seat removal ..legal ?
Last Post: Bluebottle
Today 01:02 PM
ABS warning light - possible broken cable???
Last Post: Artymorty
Today 06:42 AM
» Replies: 16
Van front seat conversion to 3 seats
Last Post: Golfbuggy
Yesterday 03:41 PM
Mk3 berlingo (2019) "boot jump plans"
Last Post: celyth
Yesterday 08:26 AM
Serpentine belt cover screws
29-04-2024 07:00 PM
