Thanks Received: 9 in 9 posts
Thanks Given: 39
My Multispace VTR was new in May this year, has done nearly 4K miles, and it's brilliant. Except that lately there's a buzzing vibration coming from the driver's door interior trim. It used to stop if I pushed it but now it's continuous and it's getting louder. It's under warranty and I've booked it in at the Citroen dealership to look at, but wonder if anyone has any advice that I can pass on to the dealer. Rattles can be a darn nuisance, and often take months of trying this and that to resolve, so any advice gladly accepted.
Thanks Received: 86 in 76 posts
The dealer will probably give everything a good tighten.
Screws working loose are the normal culprit of vibrations if this the case a spring washer usually helps.
Screws working loose are the usual cause of vibrations, if this is the case a spring washer usually helps.
Thanks Given: 44
I had similar with mine at about 2yrs old & it was window regulator mechanism come loose inside door. Fixed underwarranty.
Thanks Given: 52
mines rattled from day 1, it's on 55,000 in 11 months still rattles the same, but I'm used to them so don't hear them
but mine is a van I guess
63 plate Berlingo working hard.....
Threads: 23
Thanks Given: 48
27
Opensauce go to the top of the class
