  • 11 Vote(s) - 2.55 Average
[Engine] Intermittent noisy engine
1.9d 2001
At Idle speed the engine gets noisy (like old transit van). Problem comes and clears (could last for 5secs,10secs, 30secs )on its own. When i rev the engine the prolem clears but then could return at any time. Noticed that engine revs goes up from 900 to 950/1000 when problem is there. Happens whether engine is hot or cold. Changed egr valve and air flow sensor as these are known problems with engine. Also happens at low revs also when driving. Problem happens more in dry weather. anyone have any ideas?
Fin
sounds like injector sticking? the noise may be "nailing" caused by one cylinder getting lumpy fuel delivery or a bad spray pattern but its weird the revs rise.....could be some weird injector pump behaviour.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
(11-06-2012, 09:08 PM)Zion Wrote:  sounds like injector sticking? the noise may be "nailing" caused by one cylinder getting lumpy fuel delivery or a bad spray pattern but its weird the revs rise.....could be some weird injector pump behaviour.
Thanks Zion.
If injector sticking engine would be smoky. Feels as though timing is going out and the "tractor" takes over. I am going to disconnect EGR valve as they are known to be a problem part. Will let you know if it makes any difference.
Fin
Thanks Zion.
Fin
Air in the fuel system?
Last Post: jj9
Today 08:45 AM
Hi to all
Last Post: Oligomania
Today 08:03 AM
Today 07:17 AM
» Replies: 20
Last Post: Blakey
Yesterday 05:13 PM
Last Post: Dwight07
Yesterday 09:23 AM
Yesterday 08:45 AM
Last Post: flanagaj
01-05-2024 08:23 PM
01-05-2024 04:55 PM
01-05-2024 04:36 PM
Front seat removal ..legal ?
01-05-2024 01:02 PM
