Front and rear washers
Hi guys, haven’t been on for ages, silly busy with work and planned house move. We’ve got a problem with the front and rear screen washers on the wife’s 2003 Berlingo, they normally work fine but now and again when you lift the stalk to opperate the front washer the rear one only works. It’s got a twin outlet single pump which is fitted correctly and pumps fine just not where you want it to. Thanks in advance.
There is usually a change over relay on these single pump systems that packs up. I assume it's the same on the Berlingo.
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
