Interior light not coming on when I open the doors
Thumbs Down
Hi all, need some help with my interior light.
Works fine if I switch it on manually, but doesn't come on when I open the driver or passenger doors.
Any ideas??
Thanks......
what age ,model have you got ?
the early models have a switch in the door frame that stops working due to age etc, it is easy to replace .
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Check switches on doors. If they are ok than you need to
check if you have short circuit in lighting. If there was once
short circuit than you have to do BSI reset of power outputs.
Be careful you can only do BSI power output reset 9 times.
After that you need to buy new BSI unit !!!
I have attached BSI power output reset procedure.
Read it carefully. Check for shorts before reset procedure.
Best regards,
brajomobil
.pdf   berlingo_inter_lights_reset_bsi_eng.pdf (Size: 41.08 KB / Downloads: 60)
It's a 2012 memo van. Have looked but cant see any physical switches which confused me. Also, it doesn't work when you open either front door. Load space light still comes on when you open the rear doors though. Just weird!!
(21-01-2020, 09:35 AM)brajomobil Wrote:  Check switches on doors. If they are ok than you need to
Best regards,
brajomobil
That's interesting, especially the warning about towbars. I seem to remember seeing something about this when using Lexia but didn't know what it was relating to until now.
Back on topic...
Do the lights come on inside when you unlock the door? Only other thing that comes to mind is that maybe the switch on the light itself has got dirty so that it only works in the permanently on position?
might sound daft but it is a three way rocker switch from memory - is it in the middle position?
Yeah, in centre position and also doesn't come on with the central locking being unlocked, but works fine when physically switched on......
There are 3 wires coming to light.
1: - Ground, 2: +12v from BSI ,3: +12v permanent/constant.
When you toggle switch to 3 than light is on.
If you toggle switch to 2 then BSI needs to send +12v
In your case BSI is not sending +12V, hence no automatic light.
Best regards,
brajomobil
(21-01-2020, 09:38 AM)Scotland1976 Wrote:  It's a 2012 memo van. Have looked but cant see any physical switches which confused me. Also, it doesn't work when you open either front door. Load space light still comes on when you open the rear doors though. Just weird!!
There are no visible switches, the pickup sensors are built into the door locks.
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
