Threads: 51
Thanks Given: 23
(21-05-2012, 08:48 AM)Coco Wrote: You can make these plates from virtually anything, the end of a bean can will be fine.
Take the EGR valve off for your template and whilst it's off give it a good clean up.
You could try disonnecting it first to se if that makes any difference. Pull the actuating hose off, or unplug the solenoid (under the battery - blue plug). Bear in mind that either blanking it, removing it, or disconnecting it is likely to give MIL and long term probably limp mode every now and again. But might help eliminate.
Also, the wastegate has nothing to do with the EGR.
Yes you're absolutely right. You can blank off the EGR but not the wastegate. At least for an experiment to eliminate possible causes.
Malc
Stupid computer!
Threads: 75
Thanks Received: 1,282 in 1,134 posts
Thanks Given: 223
162
in that case check all of the boost pipe work or make up an improvised leak tester with a foot pump and a plumbing cap / tyre valve that fits in the maf pipe end, secure with a jubilee or tie-wrap and pump it up to about 15psi and see if it leaks down. It should hold solid - spray fairy liquid mix to find where the leak is if it leaks off. Bubbles will ensue!
Also Put a cloth over the tailpipe hole to hear any blowing in the exhaust (should go silent)
The following 2 users say Thank You to Sol for this post:2 users say Thank You to Sol for this post
• Ol'Jeffers, ron
Threads: 3
Thanks Received: 2 in 2 posts
Thanks Given: 2
my old van had a bad back box which caused a similar problem you could drop the box off and give it a run see if it responds better
Thanks Received: 19 in 14 posts
Thanks Given: 10
try the solonoid valve beside the battery it has 2 vacuum pipes to it and an electrical connection.if you join the 2 pipes together and rev you can hear the egr valve if it does work.then its the solonoid not expensive....it worked for me. 2.0hdi
Would my 54 plate 1.9d automatically have a dpf fitted ?
Sorry bout late response.Thanks for reply & will take that as good news. Slowly getting to grips with berlingo. Im happy with basic is best theory.
