Threads: 12
Thanks Received: 10 in 7 posts
Thanks Given: 21
Which wheels from the Citroen range will fit the Mk3 Berlingo ? I have been offered some alloys from a C5 ?
Mine is currently fitted with 15" steel OEM
Threads: 67
Thanks Given: 1,045
Your spec is 6½J-15, offset 27mm
From memory the C5 S1 and facelift were very similar, as was the C4.
• dellwood333
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
anything citroen/peugeot 4 stud and with an et of around 25 should fit ok, peugeot 307/308-citroen c4/c5 also have a similar rolling radius on the tyres if the they have them fitted, you will need the correct alloy wheel bolts for them, ive done a bit of research and 206/207/208/307/308/c2/c3/c4/c4picasso/c5 4stud will fit gen 3 berlingo, ive just picked up a set of 18" c4 picasso atacamas for mine
