02-12-2013, 04:35 PM
Hi
my exhaust has recently been dying a death. i patched it up with a steel pipe as the existing pipe has corroded right through. this happened at the front of the cat, my bodge seemed to sort out the loud jet like noise
yesterday the rear of the cat corroded right through and it ended up in the middle of my road...
basically my cat had dropped out...( mk2 2006 1.9D )..so now ive decided to get it fixed properly.
after hours of research and not even knowing the middle box was a cat..ive narrowed it down to this part
http://www.eurocarparts.com/ecp/c/Citroe...054&000059
can someone please confirm if this is the right part...will i need anything else to fix my problem..as ive also found this and they look different.
http://www.gsfcarparts.com/215pc1420
cheers
cheers
