  • 2 Vote(s) - 4.5 Average
Drive shaft gaiter clamp
Went to my local Citroen dealer to day with a broken gaiter clamp to have it replaced under Citroen select warranty they told warranty did not cover the clamp as it was wear and tear £46.20 to fit the clamp i told them it was wear and tear if the rubber gaiter had failed but the clamp was component failure they said pay now and they would try to claim it back as luck would have it i had the warranty with me looking at the small print it said if the car would fail an MOT with in the 12 months of perches they would cover it i pointed this out he went a way to make a phone call came back said all covered under warranty :woop: :woop: So all ways look at the small print
  • addo
It's a real shame when business start acting like that. Poisons the goodwill.
While my car was under warranty I always found an email to Citroen UK via their website worked wonders. The dealer was erring on side of caution as if they do warranty work not ok'ed by Citroen UK then they don't get paid. In the past I had gear lever gaiter split, told by dealer not covered as cosmetic, email to Citroen & dealer is phoning to bring it in for warranty repair.
(25-01-2014, 01:05 AM)addo Wrote:  It's a real shame when business start acting like that. Poisons the goodwill.
A bit of goodwill go's a long way but no you've got to fight to get things done all you need is to be treated fair do i take it to them 30 day's before mot run's out for an mot and if it failed do tell them they can fix it under warranty?? is that fair . When service time comes around do i take it to them yes if they looked after me if not look for some one else .
(25-01-2014, 12:31 PM)Opensauce Wrote:  While my car was under warranty I always found an email to Citroen UK via their website worked wonders. The dealer was erring on side of caution as if they do warranty work not ok'ed by Citroen UK then they don't get paid. In the past I had gear lever gaiter split, told by dealer not covered as cosmetic, email to Citroen & dealer is phoning to bring it in for warranty repair.
Thanks i will make a note of that
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
