  • 7 Vote(s) - 2.43 Average
Number Plate bulbs
Hello fellow Berlingo fans!
Please can someone help me? I have a failed number plate bulb on 'Bernice the Berlingo', a mk2 Multispace XTR, and do you think I can see how to replace the bulb..??..!!
Any advice gratefully received please, I've had a poke around but was reluctant to force the lens too much
Many thanks
Steve & Helly
Calne, Wiltshire
- WV56 KXB - 2006 1.6HDi XTR in Iron Grey + air con
'Alfonse the 2CV' - DDG 643Y - 1983 2CV Club in Blue & Yellow
'Norman the Nemo' - WU09 XFJ - 2009 Nemo 1.4HD1 LX van in Blue
What sort of rear end has it got? One single tail gate or the doors?
Hi Andre,
Bernice has a single tailgate
Steve & Helly
Calne, Wiltshire
I have done this. Went through the interior trim I am due to do this again as want to look at the bulbs and was going to make a how to. After the trim is off there is thin foam over the holes I had to break through this. It was awkward to get to but thats the way I done it but Haynes suggests differently. If you go through the trim be careful when pushing back on
Lliam
Lliam
53 plate Berlingo Multispace Forte 1.9D Polar White
[-] The following 1 user says Thank You to lemsworld for this post:
  • steve+helly
Treat bernice....
[-] The following 1 user says Thank You to Andre for this post:
  • steve+helly
Smile
Thank you both for your quick replies, looks like a job for next weekend! Thanks again
Steve & Helly
Calne, Wiltshire
This is to see the lamp, and prepared to do a kind of. After cutting off a thin foam in the hole, I had to break it. This is embarrassing to go, but thats the way I did it, but Haynes put forward different views.
Yesterday 10:57 PM
Rear Suspension Rebuilders?
Yesterday 08:02 PM
Yesterday 07:45 PM
Bolt torque settings
Yesterday 07:21 PM
Yesterday 06:07 PM
Yesterday 03:06 PM
roof rack
Last Post: Vowders
Yesterday 12:33 PM
Yesterday 10:59 AM
Last Post: Wightlingo
Yesterday 07:56 AM
Yesterday 06:51 AM
