Iphone 4 auto Bluetooth connect
Evening all
Just got my 13 plate enterprise and got a couple of questions which I'll post on 2 threads.....
I can pair my iPhone 4 to the Bluetooth however every time I get in the van I need to re-pair the phone (ie. the radio doesn't remember my phone and doesn't auto connect via Bluetooth as you'd expect)
Anyone got any ideas how to resolve?
Gonna try with my mrs's iphone 5 and also the iPad to see if they'll connect then auto connect again once the ignition is turned off and back on.
Was hoping someone had the same problem but had a fix!
iPhone 5C is fine, as is a normal iPhone 5, and iPod touch all pair. the phone has to be within reach when you start the engine, did you pair the van to the phone or the phone to the van, do it from the Van stereo options
63 plate Berlingo working hard.....
[-] The following 1 user says Thank You to ATL_driver for this post:
  • doofer
(13-02-2015, 10:37 AM)ATL_driver Wrote:  iPhone 5C is fine, as is a normal iPhone 5, and iPod touch all pair. the phone has to be within reach when you start the engine, did you pair the van to the phone  or the phone to the van, do it from the Van stereo options
Cheers - it's not that it won't pair.......its that it won't pair automatically after the first time I've paired the devices.
Had it at Citroen today and they agree and had the same problem on a 14 plate they had in. Service manager didn't have a solution but grateful if any other users on here can confirm their iPhones pair and then pair automatically each time they get in the van....
yes 3 different aged iphones all pair as does an ipod, and that's for the Bluetooth music and phone calls, even with the phone pairing with my garmin at the same time....
what I mean from my last post is, if you pair the van from the phone it might not auto pair next time, if you pair from the vans settings to the iPhone it'll search for your phone every time you start the van...
(24-02-2015, 02:18 PM)ATL_driver Wrote:  yes 3 different aged iphones all pair as does an ipod, and that's for the Bluetooth music and phone calls, even with the phone pairing with my garmin at the same time....
Been into the dealer again today and they say they've tried pairing phones on 4 13/14 plate berlingos and none of them auto-pair. They're now saying that this is "just the way it is" and that's the correct functionality.
I can't believe that the correct functionality is to have to fully pair the phone every time you turn the ignition off but not sure how I can get the dealer to agree!
Can anyone help?..
Can anyone help?..
have you tried pairing from stereo to phone instead of phone to stereo?
(04-03-2015, 07:35 PM)doofer Wrote:  Mine's been fine since I re-paired it.
Before I lost it I disabled media but kept the calls option.  I don't know whether this is a factor.  This time I've left everything enabled.
Tried pairing from stereo to phone and vice versa. Tried when stationery, when moving. Tried Removing everything and restoring all settings on my phone but no joy. It pairs then doesn't re-pair automatically next time.
Citroen HQ kindly said try another dealer (!) so I'm booked into another dealer on 18th March now!
Hi did you manage to get to the bottom of this? I have a 64 plate with same problem
Berlingo 2007 1.6 hdi - intermittent sticky acce...
Last Post: Dwight07
Today 09:23 AM
brake master cylinder
Last Post: BigVtwin996
Today 08:45 AM
Can you clamp the rubber brake hose?
Last Post: flanagaj
Today 07:06 AM
Are brake pistons / seals a common size?
Last Post: flanagaj
Yesterday 08:23 PM
Brake lights in spite of changed BSI - need advi...
Yesterday 04:55 PM
Kjøleviften går ikke oransje trekant kommer opp ...
Yesterday 04:36 PM
Front seat removal ..legal ?
Last Post: Bluebottle
Yesterday 01:02 PM
ABS warning light - possible broken cable???
Last Post: Artymorty
Yesterday 06:42 AM
» Replies: 16
Van front seat conversion to 3 seats
Last Post: Golfbuggy
30-04-2024 03:41 PM
Mk3 berlingo (2019) "boot jump plans"
Last Post: celyth
30-04-2024 08:26 AM
