11-06-2015, 07:50 PM
Hi guys, I've only been a Berlingo owner for 3 months and it appears I have developed my first fault.
My Berlingo is a 14 plate 1.6 Diesel multispace (Semi Auto) and Im using it to do delivery work.
On average it will be required to start and stop some 60-80 times a day/6 Days a week which is not a small ask of any vehicle. My previous Toyota did this faultless for some 6 years straight without missing a beat.
All's been going with the Berlingo until this last couple of weeks, Its started having completely random issues restarting. I pull up to an address, The Eco-Off will usually stop the engine if I've got my belt on and I remove the key while the engine is off in eco mode.
When I put the key back in and cycle the starter the engine will not start, It just chugs away under the starter's power. I then have to resort to holding the accelerator pedal 80% open and cycle the starter 3-4 times for around 3 seconds a time before the engine fires.
This has only happened around 5 times in the last 2 weeks but today it happened twice in the space of 3 hours and now has me worried.
After it eventually starts everything becomes normal again and even if you immediately stop and restart the engine it will work perfectly normal. Its not a consecutive thing and has been unpredictable. The issue has never occurred when the Stop/Start system runs when driving around, only when I take the key out and do a delivery.
One thought that went through me head today, Could this be the Stop/start system that's causing it? Engine Eco's off and prepares itself to restart on its own but I then pull the plug by switching the ignition off while its in eco off mode? Could I be confusing it?
Should I be making sure the engine running when I pull the Key? (Taking the belt off is a quick way to do this)
The reason Im thinking this is because It never seems to develop the issue when the engine is shut off by me turning the key.
Today after it did it on the morning I started pushing the button to disable the Start/Stop system but after doing it some 20+ times I gave up which was when it then did it again!
I really appreciate any thoughts on this issue as I have no Idea when it comes to engines etc and could be barking up the wrong tree for all I know.
Until I can find the time to get it into a garage Im stuck guessing.
PS, I hope this is the right section of the forum to post this!
