  • 21 Vote(s) - 2.76 Average
1.6 hdi oil filter
Howdy - just a quick (and very stupid question). Im used to servicing my old 2.0hdi with the 'old fashioned' metal oil filter but my new 2007 1.6 hdi has one of these silly 'vacuum cleaner' type card oil filters. Having gone to fit it, my question is... WHERE IS IT ON THE ENGINE!?!? is it underneath, is it on top? advice greatly appreciated - thanks
is this any help to you mate?
http://wiki.answers.com/Q/How_do_you_cha...go_1.6_hdi
Quote:on the 1.6 HDI diesel engine, it's located under a black plastic housing on the right side about half way down. There's a big nut cast into the top of the housing that you undo (carefully) with a socket wrench. You will probably have to remove the top air intake hose to gain access to the housing. Once the housing is removed give the filter a sharp tug to remove it - it's not fixed by anything. Replace with a new filter and sealing washer.
[-] The following 2 users say Thank You to steve valentine for this post:
  • Dizzydi, mrgreencar
When I first changed mine I really had to pull on the filter to get it out of the housing. When you replace it you need to do the O-ring too on the housing cap (the plastic bit with the hex nut on top). The nipple on the bottom of the filter needs to fit into the recess in the engine. Make sure it is sitting in the recess before tightening. You tighten the cap to 25nm torque.
[-] The following 1 user says Thank You to 3rensho for this post:
  • mrgreencar
Thanks for both your replies - now I've found what Im looking for it should be a piece of cake!
Having taken off the engine shield, also noticed the lower bracket on the exhaust manifold cowling has snapped so will fix that at the same time.
thanks guys Smile
Do thing right themselves?
Last Post: Anyinfo
Yesterday 10:57 PM
Yesterday 08:02 PM
Thoughts on Leisure battery powering radio when ...
Yesterday 07:45 PM
Bolt torque settings
Yesterday 07:21 PM
Solenoid location
Last Post: OMG
Yesterday 06:07 PM
2012 1.6hdi Won't start!
Yesterday 03:06 PM
roof rack
Last Post: Vowders
Yesterday 12:33 PM
Oil sump design.
Yesterday 10:59 AM
Amdro Dometic Origo stove can it be changed to g...
Last Post: Wightlingo
Yesterday 07:56 AM
buying advice - bonnet release lever broken
Yesterday 06:51 AM
