tyre wear
hi all , under the car (multispace 1.9d 03 model) the weekend ,and i noticed wear on the inside edge of the rear o/side tyre ??? i've never seen this before ?? can anyone shed some light on this please ?? thanks in advance !!
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
If it's fitted with rear torsion bar suspension (I think that model is) the swing arm bearings tend to eat themselves giving the wheel a strange negative camber.
Take a look at the axel from the rear and does that wheel look like it's leaning inwards?
Mine was like that (both rear tyres) for over 15k miles and it never got any worse, likewise i've heard stories of bearings collapsing so bad the wheel rubs the arch. http://www.imaxle.co.uk do recon rear axles for a decent price
thanks for your reply Munkey much obliged !! can the bearings be replaced ????
Yes the bearings can be replaced, but it's a difficult complicated time consuming job, add to that, if the bearings are knackered the axle pins will also be in the same state and they are almost impossible to change unless you have special equipment, you really are better off getting a reconditioned axle.
Take a look at the thread below, it details how to tell if the axle bearings are gone...
https://www.berlingoforum.com/thread-2996.html
The thread below details how to fit grease nipples to the axle, this in most cases buys you a lot of time and is worthwhile even if the bearings seem to be ok.
https://www.berlingoforum.com/thread-10879.html
As for the tyre ware, if the tyres you have are not directional you can have the tyre removed from the wheel and turned, so the inside edge is now on the outside, thus giving you twice the life from the tyre!  Wink
  • Art b
JJ9 thank you very much indeed ! i am very grateful for your reply !!!
[-] The following 1 user says Thank You to my mucker for this post:
  • jj9
Tyre pressure monitor
Last Post: Blakey
Yesterday 05:13 PM
Berlingo 2007 1.6 hdi - intermittent sticky acce...
Last Post: Dwight07
Yesterday 09:23 AM
brake master cylinder
Last Post: BigVtwin996
Yesterday 08:45 AM
Can you clamp the rubber brake hose?
Last Post: flanagaj
Yesterday 07:06 AM
Are brake pistons / seals a common size?
Last Post: flanagaj
01-05-2024 08:23 PM
Brake lights in spite of changed BSI - need advi...
01-05-2024 04:55 PM
Kjøleviften går ikke oransje trekant kommer opp ...
01-05-2024 04:36 PM
Front seat removal ..legal ?
Last Post: Bluebottle
01-05-2024 01:02 PM
ABS warning light - possible broken cable???
Last Post: Artymorty
01-05-2024 06:42 AM
» Replies: 16
Van front seat conversion to 3 seats
Last Post: Golfbuggy
30-04-2024 03:41 PM
