  • 29 Vote(s) - 3.59 Average
Screen Wash Pump and Diesel Preheat
Hi
If anyone can help diagnose this problem it'd be appreciated.
At the same time the screen wash pump and the diesel preheat light on the dash seem to have stopped working. I thought it must have been a fuse but can't see any blown.
If anyone has any ideas...
Cheers
Adri
Adri is it just the preheat light or is it not preheating ?
I think it is preheating as the car starts just the same. Can't be 100% certain though. I'm sure it's an electrical fault as the two systems have died at the same time.
Scanning through my Haynes manual at the moment but I don't find them very good for diagnosing...
Thanks for the replies.
adri
Sounds like a fuse you may need to test them with a meter or by replacement as you can not always see that they have blown
You can check out a fuse guide here: http://www.berlingoforum.co.uk/showthread.php?tid=109
If not a fuse maybe the bulbs? Just a suggestion. With the Haynes manual you should be able to work your way into the instrument panel
Lliam
Lliam
53 plate Berlingo Multispace Forte 1.9D Polar White
Does your pre-heat light come on that much anyway? Mine only ever comes on when it's really cold.
My pre-heat light shows up even on a hot day. If it's hot it's only for a second. But cold it's on a bit longer
Lliam
Lliam
My preheat has only been on in the cold weather but the washers to both front and rear screen have been a bit problematic during the freezing weather. The washer jets (presumably) seem to freeze up at the slightest hint of frost so I've been putting a drop of methylated spirits in with the screenwash water to prevent freezing.
Shocked
re-I've been putting a drop of methylated spirits in with the screenwash water to prevent freezing
dont think I will try that, the last thing I want is a couple of drunks sucking on my nipples
Do thing right themselves?
Last Post: Anyinfo
Today 10:57 PM
Today 08:02 PM
Thoughts on Leisure battery powering radio when ...
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Solenoid location
Last Post: OMG
Today 06:07 PM
2012 1.6hdi Won't start!
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Oil sump design.
Today 10:59 AM
Amdro Dometic Origo stove can it be changed to g...
Last Post: Wightlingo
Today 07:56 AM
buying advice - bonnet release lever broken
Today 06:51 AM
