  • 7 Vote(s) - 2.43 Average
Wheel arch liners removal
Basically I lost the cap that goes over the rear of the headlamp unit down the nearside/left wing. Are the liners easy to remove? Anyone know how much those caps are from Citroen? I might just buy a another one :lol:
This must be the only vehicle I've owned where an oil change I could do blind-folded, took about 20 minutes including tidy up, but changing the headlight lamps is one of those jobs where you think "Wish I hadn't bothered!"
It just sort of slipped out of my hand as I hadn't removed the air intake pipe that goes from airbox to radiator! :brickwall:
The more I tried to reach it the more I pushed it into a slot and out of reach :lol:Bastard thing
Still, nice fresh oil and filter, and no need to get the ramps out! :woop:
Can't you get one of those flexible claw type thingies cheaply, good for getting into nooks and crannies and retreiving stuff...
Here's a start for you:-
http://www.berlingoforum.co.uk/showthread.php?tid=457
Cheers! Big Grin
Well that MUCH easier than I thought it would be! A bit fiddly, but easy enough.
Only reason I'm bumping is just to say there was a huge amount of crud behind the passenger side liner, trapped between the inner and outer wing near the door. It was soaking wet, and a definite rust trap even on a galvanised vehicle!
(28-01-2012, 03:41 PM)chronyx Wrote:  Only reason I'm bumping is just to say there was a huge amount of crud behind the passenger side liner, trapped between the inner and outer wing near the door. It was soaking wet, and a definite rust trap even on a galvanised vehicle!
Didn't realise that the Berlingo had a galvanised chassis ???
Oh doesn't it? I've never seen a rusty Citreon or Peugeot so just assumed they were Big Grin
All the more reason to get the mud out of there!
[-] The following 1 user says Thank You to chronyx for this post:
  • andy-womble
Do thing right themselves?
Last Post: Anyinfo
Today 10:57 PM
Today 08:02 PM
Thoughts on Leisure battery powering radio when ...
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Solenoid location
Last Post: OMG
Today 06:07 PM
2012 1.6hdi Won't start!
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Oil sump design.
Today 10:59 AM
Amdro Dometic Origo stove can it be changed to g...
Last Post: Wightlingo
Today 07:56 AM
buying advice - bonnet release lever broken
Today 06:51 AM
