Threads: 121
Thanks Given: 248
34
I'm obviously doing something wrong as both of my driveshaft boots have become loose on the driveshaft after I replaced the boots some time ago. One of the clips has worm through the boot as a result and the other is about to do the same so I'm replacing them both.
I've not had any problems with the clip on the CV joint, just the driveshaft. I have the correct crimp tool & wonder if I'm over tightening them? It's also possible that I pulled the boots too far along the driveshaft before tightening them so will pay a bit more attention to that this time as there's a marker groove in the driveshaft that I might have ignored last time.
Has anyone seen any good videos or write ups on the subject? All positive tips on how to do this welcome!
Threads: 61
Thanks Received: 699 in 597 posts
Thanks Given: 192
45
Not too tight and dry under the boot at fixing points seems to work for me.
Serieal Berlingo owner
• cancunia
Threads: 10
Thanks Received: 27 in 26 posts
Thanks Given: 6
17-07-2023, 04:50 PM
(This post was last modified: 17-07-2023, 04:54 PM by ItsGreen.)
Is it a plastic boot or a rubber one? I've never got on well at all with the plastic ones.
I fitted a pair of stretchy ones from Wilco on Wragby Road on my 2006/2.0HDI, and 10k later, they're still there. I use the metal clip on the inner (big) end of the boot and nip it with a pair of joiners pincers, drive about for a day so it settles as far along the shaft as it wants to be, then put a cable tie on the outer (thin) end.
Threads: 121
Thanks Given: 248
34
Thanks both. It's a plastic boot as those were all that I could find. I might well try the cable tie approach on the drive shaft this time.
Threads: 12
Thanks Received: 45 in 40 posts
Thanks Given: 35
11
I bought some stainless steel drive shaft clips 'jubilee clip style' from ebay which worked well for me. I couldn't use them on cv end of shafts because of clearance but tightened well on shaft end.
I orientated them so that when rotating forwards they won't hook anything with the nut end on the clip.
I find the drive shaft clips provided with the boot kit a pain to fit on the small end.
The following 1 user says Thank You to Kieron G for this post:1 user says Thank You to Kieron G for this post
• cancunia
Threads: 10
Thanks Given: 6
Probably just stuck it in a full lock and laid down. Like I say, I'm not a fan of the thermoplastic boots at all. I've tried to fit them a few times and they always ended up coming off.
The following 1 user says Thank You to ItsGreen for this post:1 user says Thank You to ItsGreen for this post
• cancunia
Threads: 121
Thanks Given: 248
34
A quick update on the saga, no work done on the passenger side today due to rain but I did get the driver's side mostly back together yesterday and today I did the final tightening of the drive shaft nut, so took the wheel off to get the 'R' clip back on.
The boot has moved slightly along the shaft from where I fitted it yesterday and the wheel has only turned a few times... Maybe it's meant to?
Threads: 13
Thanks Received: 30 in 22 posts
Thanks Given: 8
You need the Knipex Oetiker (Oetiker are the manufacturer of the clips) pliers to do them properly.
Regarding the CV boots - I get them (and all my parts) from Autodoc of Germany as they sell GKN Lobro who are OEM for CV boots. Anything less isnt worth messing about with due to the hassle of getting to the boots to replace them.
2004 Peugeot Escapade 2.0HDI. 83k miles
2004 Volvo V70 2.4 200k miles
2011 Volvo XC90 215k miles
