  • 11 Vote(s) - 2.82 Average
Clutch Noise
Hello All
Currently in France with a clutch which produces a high pitch squeal when depressed (it's not the only one). It will sometime whistle as it travels along.
The Norauto garage (similar to Kwikfit) say a new clutch is required for 700 Euros (£600)
Anyone have any experience of this problem? Car drives fine part from the noise when changing gear.
Is the price reasonable?
1.6HDi 2007
Hi, Sounds probably more like the clutch release bearing.
Is it more like a whine when traveling normally?
Confusedalut:
[-] The following 2 users say Thank You to Rustscrat for this post:
  • Bryce, ron
I agree with Rustcrat.Used gently,it should get you home where you have a choice of repairers in your area(not so far to go if it goes wrong).
Just keep off the clutch pedal as much as possible.
Good luck whichever you decide.
  • Bryce
I agree with the others! my clutch release bearing made similar noises when on its way out. The plastic part of the bearing wears and melts, gets worse then falls apart. Ours went on for 3 days and when i stripped it there was really nothing left of the bearing! eek!
Sent from my GT-I9000 using Tapatalk 2
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
[-] The following 1 user says Thank You to divingscubaboy for this post:
  • Bryce
Agreed it definatly sounds like the release baring..mine started squeling then collapsed shortly afterwards! Get it to a garage asap IMO
Sent from the dark side of the moon using Tapatalk
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
[-] The following 1 user says Thank You to PeteA for this post:
  • Bryce
Thanks to all who replied. I got back home £580 lighter but the Bingo sounds a lot healthier.
It was the clutch release bearing true enough - the chap showed be the parts and it looked pretty mangled. I guess after 94K miles it is expected.
Cheers
Mine is on the original clutch at 135k
My cat is black............................160k
(15-04-2012, 11:18 AM)Bryce Wrote:  Thanks to all who replied. I got back home £580 lighter but the Bingo sounds a lot healthier.
Cheers
Its the shaft which operates the release bearing which seizes at the lower end. This then holds the bearing against the clutch pressure plate so the bearing is running all the time and starts to overheat thus melting the plastic parts
Cool
(15-04-2012, 03:27 PM)Coco Wrote:  My cat is black............................160k
Ahh but i have a panther called midnight!
Do thing right themselves?
Last Post: Anyinfo
Today 10:57 PM
Today 08:02 PM
Thoughts on Leisure battery powering radio when ...
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Solenoid location
Last Post: OMG
Today 06:07 PM
2012 1.6hdi Won't start!
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Oil sump design.
Today 10:59 AM
Amdro Dometic Origo stove can it be changed to g...
Last Post: Wightlingo
Today 07:56 AM
buying advice - bonnet release lever broken
Today 06:51 AM
