Threads: 2
Thanks Given: 6
I’ve just ordered a comm2000 for my Berlingo van. I did a search on the forum and found some good advice on fitting, but my Haynes manual says that it must be fitted by a dealer as it has to be coded to the BSI. None of the posts mention coding to the BSI, but as this is a new unit and not second hand, would this make a difference?
I did find a comm2000 reset procedure, would this do the trick?
Thanks in advance guys.
Threads: 11
Thanks Received: 9 in 7 posts
It may need coding. My Partner had a replacement comm2000 recently before I bought it & was incorrectly configured as my front foglights wouldn't switch on. Once the specialist plugged the PP2000 into it & configured it correctly it was all good again. If it was a simple case of plug it in & all works, I wouldn't have thought mine would have been configured at all, let alone incorrectly.
2000/X Peugeot 406 110 HDi LX Family 93k to
2000/W BMW 530D SE Auto 84k to
2003/03 Peugeot Partner Escapade 95k
Standard so far
[Image: Signature.jpg]
The following 1 user says Thank You to waue1978 for this post:1 user says Thank You to waue1978 for this post
• compdoc
Threads: 41
Thanks Received: 30 in 27 posts
Thanks Given: 16
Mine didn't need coding.
Sent from my ST21i using Tapatalk 2
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
Pretty sure the fogs, cruise control etc are all configured in the Bsi and as you're not changing this you should be ok.:thumbsup:
2006 2.0hdi 600 with bench seat.
Threads: 2
Thanks Given: 6
Thanks guys, I feel a bit more confident in changing it now. But I've got the phone number of a local specialist in case it doesn't work.
I'll update the post as soon as I get it on (weekend I hope) so that future Berlingo newbies, like me, can see the results when searching.
Threads: 2
Thanks Given: 6
Got the com2000 changed without major problem and everything worked OK except the screen washers. But then they didn't work before so I guess a new pump is in order as I can't hear the pump and disconnecting the pipe also produces no water.
I did take about half hour unclipping the steering wheel airbag, through three little holes in the back of the steering wheel. Each time I got to the last one the others clicked back into place, but got there in the end with a few screwdrivers wedged in the slot.
Also radio didn't need a code despite the battery being off for an hour, so good news alround.
Threads: 61
Thanks Received: 699 in 597 posts
Thanks Given: 192
45
23-09-2012, 08:31 PM
(This post was last modified: 23-09-2012, 08:32 PM by geoff.)
Don't think me rude but what does the com2000 cost ? Hopefully I never need one. P.S well done on a good result !
Serieal Berlingo owner
Threads: 18
Thanks Given: 211
Hi, what will you be doing with your old unit as I'm looking for parts for a test rig. :drool:
:thumbsup:
Threads: 2
Thanks Received: 14 in 11 posts
Thanks Given: 24
Geoff; Comm2000 cost me in the region of 130.
compdoc; lack of screenwash motor operation could also be the fuse. My handbook mentions fuse location if my memory serves me. You may get both the fuse and the motor kaput in the same instance.
