  • 5 Vote(s) - 3.2 Average
Berlingo 1.9d not starting in morning
So my Berlingo won't start in the morning. I've had heater plugs replaced, I've primed fuel pump until it's firm, no air bubbles and still no start. I have to get a push start every morning to get it going but once it's going, it will restart generally fine after that for the day. Managed to get it started with easy start spray too.
Any ideas?
Are the glow plugs coming on?
  • mugatea
(01-09-2013, 08:37 AM)addo Wrote:  Are the glow plugs coming on?
I don't know, but the mechanic doesnt seem to think they are the problem.
You need fuel, air, compression - and a little warmth to kick it off. I'd first check the glowplug relay, then the pump timing. Not sure what cold start mechanism it has on the pump, but someone else will have an idea on checking this detail.
  • mugatea
My cold start mechanism wasn't working when I bought the car. Someone had tweaked it so it was permanently on fast idle. When I reset it to normal idle it wouldn't start easily. Or rather it would start then it would die until the engine had warmed up a bit.
I'm fairly sure someone on here told me the part no. then I bought one but can't remember if it was from the dealers or from ebay. You'll need a 32mm spanner if you do decide it needs changing.
Malc
Stupid computer!
[-] The following 1 user says Thank You to crickleymal for this post:
  • mugatea
A few days i has one Berlingo 1.9d whit that problem. The glowplug relay burn and don´t work. Put a wire in the positive of the batery and on the glowplug and turn on the van... If it works is the relay...
sorry for my language.
[-] The following 2 users say Thank You to andre 21 for this post:
  • mugatea, Ol'Jeffers
(01-09-2013, 07:54 PM)andre 21 Wrote:  A few days i has one Berlingo 1.9d whit that problem. The glowplug relay burn and don´t work. Put a wire in the positive of the batery and on the glowplug and turn on the van... If it works is the relay...
Thanks for that. Where is the glowplug relay on a berlingo?
It's on the passenger wing
Yes, in the UK, is in the passeger wing, on side of the headlamp. It´s green. And cost 58€ on the Citroën here...
It will be the valve clearances, the valves recede into the seats with mileage, and then you loose compression as they begin to not close properly. Usually happens at @120/140 K miles.
I have had to do them twice on my C15 van 267K miles nowSmile
This is assuming glow plugs working, and no air in fuel, which you seem to have done already.
  • addo
Do thing right themselves?
Last Post: Anyinfo
Yesterday 10:57 PM
Yesterday 08:02 PM
Thoughts on Leisure battery powering radio when ...
Yesterday 07:45 PM
Bolt torque settings
Yesterday 07:21 PM
Solenoid location
Last Post: OMG
Yesterday 06:07 PM
2012 1.6hdi Won't start!
Yesterday 03:06 PM
roof rack
Last Post: Vowders
Yesterday 12:33 PM
Oil sump design.
Yesterday 10:59 AM
Amdro Dometic Origo stove can it be changed to g...
Last Post: Wightlingo
Yesterday 07:56 AM
buying advice - bonnet release lever broken
Yesterday 06:51 AM
