heavy clutch
Threads: 5
Hi
I brought a 2003 HDi 2l diesel last month, my parents test drove it and collected it, i never drove it before it was brought as it was brough up north and i live in the SW
I find the clutch really heavey and it bites very low down. I have driven other diesels vehicles before cars, vans, pick up land rovers and never had this problem.
Basically when i pull off in 1st i dont need to press accelorator at all on the flat and it races away at 5+ mph. It stalls if there is a gradient when i have to use a bit of accelorator. I know diesels have a bit of creep, but these a bit too much . I drove a belingo as a hire car 5 yrs ago and didnt have a problem then.
Also there is a slight intermiting juddering when in nuetral
Is this the norm? There are other niggly problems for another thread ideon:
Threads: 32
Thanks Given: 24
Where in the S.W. are you?
Threads: 5
(16-06-2011, 07:27 AM)Coco Wrote: Where in the S.W. are you?
somerset
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
Personally I found both my bingos bite low down even after replacing the clutch on one of them. I find you really need to makes sure the pedal goes right down. Are sure its a heavy clutch? the cables have a habit of becoming very stiff and you may find a few quid on a cable will make a noticeable difference.
Sent from my GT-I9000 using Tapatalk
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte. alut:
Threads: 25
Thanks Received: 234 in 131 posts
Thanks Given: 44
12
(15-06-2011, 08:45 PM)mar mite Wrote: Hi
Before to replace clutch kit, replace clutch cable.
Threads: 12
Thanks Received: 27 in 21 posts
Thanks Given: 31
Same on mine, 2.0hdi. Thinks its probably because we are used to hydraulic clutches these days, so when you get into one with a cable operated clutch it feels heavy
Threads: 3
Thanks Received: 3 in 1 posts
Thanks Given: 4
(19-06-2011, 01:12 PM)800HDI Wrote: Same on mine, 2.0hdi. Thinks its probably because we are used to hydraulic clutches these days, so when you get into one with a cable operated clutch it feels heavy
This is what I've told my wife, she's struggling with the heavy clutch on the berlingo, our 2 pug coupes are both hydraulic clutches so light as a feather. Is there an adjustment for the clutch cable on the berlingo? Our clutch is brand new, but theres some play at thw top of the pedal travel before you feel it start to move the clutch plates.
Threads: 13
Thanks Given: 7
Did you renew the cable with the clutch. The cables have an adjuster built in which is non serviceable. Also check the routing is correct. There is a plastic spring assembly on the pedal inside the vehicle, its worth lubricating it. Careful not to lubricate the pedal rubbers though!
Sent from 2 bean tins and a piece of string!
Threads: 11
Thanks Received: 9 in 7 posts
I think the heavy clutch is par for the course with these. I've got used to it, but it's always murder driving my car after I've had a company car for a day as it feels even heavier afterwards.
2000/X Peugeot 406 110 HDi LX Family 93k to 2000/W BMW 530D SE Auto 84k to 2003/03 Peugeot Partner Escapade 95k
Standard so far
[Image: Signature.jpg]
Threads: 3
Thanks Given: 4
(13-12-2012, 04:56 PM)divingscubaboy Wrote: Did you renew the cable with the clutch. The cables have an adjuster built in which is non serviceable. Also check the routing is correct. There is a plastic spring assembly on the pedal inside the vehicle, its worth lubricating it. Careful not to lubricate the pedal rubbers though!
Thanks, i shall check inside the car, the cable looks new from when i was undernath changing the oil, i didn't change the clutch myself, some garage did for the previous owner, they did leave the bottom LH engine mount loose though!
Today 08:02 PM
Thoughts on Leisure battery powering radio when ...
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Solenoid location
Last Post: OMG
Today 06:07 PM
Do thing right themselves?
Last Post: tdonbay
Today 05:44 PM
2012 1.6hdi Won't start!
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Oil sump design.
Today 10:59 AM
Amdro Dometic Origo stove can it be changed to g...
Last Post: Wightlingo
Today 07:56 AM
buying advice - bonnet release lever broken
Today 06:51 AM
