Good thermal efficiency of our engines can be a downside !!
Threads: 33
Thanks Received: 21 in 20 posts
Thanks Given: 22
Mine is a 2005 2.0Ltr HDi
In this recent cold weather I have noted that when, either poodling around the country lanes, or parked up, engine running, the high thermal efficiency of the engine means that, if one puts the heater on, the engine temperature drops to well below normal!! Not all that handy when sitting around having a coffee or parked up messing about on the CB radio!!
Of course, when driving around under more "normal" conditions, the engine temp remains normal, but under low load situations, put the heater on high and the gauge drops very noticeably.
There is nowt wrong with my thermostat etc, so this is not a request for help, just an observation.
Regards to all,
John - (2005 2.0HDi with Modutop roof, mini camper).
Thanks Given: 316
15
Yep thats an oil burner for you!
Threads: 7
Thanks Received: 207 in 121 posts
Thanks Given: 16
8
09-12-2017, 08:51 AM
(This post was last modified: 09-12-2017, 08:53 AM by Gravity.)
Most cars in this country are massively overcooled. The same vehicles are sold to hot countries, so the cooling system is built so as not to overheat in what, to us, are blistering temperatures.
On every car I've had I have always blanked off a large section of the front grille. This has not only given me a better heater, but better fuel consumption also.
I blank the grille from behind it where it can't be seen, usually by fastening a shaped piece of stiff plastic to it (thank you Estate Agents!)
With thermal efficiency comes less heat generation, so modern engines need all the help they can get.
Gravity
Threads: 16
Thanks Received: 54 in 17 posts
Thanks Given: 4
8
11-12-2017, 09:52 AM
(This post was last modified: 11-12-2017, 09:53 AM by iscom.)
Just out in interest . . . On Saturday with the temp being around 1 to 2- I did a short round trip maybe 5 miles stopping about three or four times on returning home and parking on the drive I heard the cooling fan on and it remained on for a few minutes but I can't remember hearing the fan before, even during the summer
Thanks Given: 316
15
(11-12-2017, 09:52 AM)iscom Wrote: Just out in interest . . . On Saturday with the temp being around 1 to 2- I did a short round trip maybe 5 miles stopping about three or four times on returning home and parking on the drive I heard the cooling fan on and it remained on for a few minutes but I can't remember hearing the fan before, even during the summer
If you have a new new Berlingo it stays on to cool the turbo if short journeys at low speed are detected.
If its a older Berlingo it may indicate your cooling system has partially frozen and air locked.
Difficult to say - what did tempature gauge say?
Threads: 19
10
The Fan will be on as Your DPF is crying out for a regen - assuming you have a newer vehicle. Your DPF has started its regen but not completed it - the fan will be cooling under bonnet temps created by the partial regen.
Mine occasionally does it despite doing 150 miles a day motorway driving
Threads: 7
Thanks Given: 16
8
V (11-12-2017, 10:01 AM)polar Wrote: If you have a new new Berlingo it stays on to cool the turbo if short journeys at low speed are detected.
Bear in mind that in this instance, with minus ambient temperatures and a short journey of five miles, the turbo is lightly loaded and would not need much cooling.
As said, possibly the fan was on as part of a failed regen.
Gravity
Thanks Given: 316
15
(11-12-2017, 11:28 AM)Gravity Wrote: V (11-12-2017, 10:01 AM)polar Wrote: If you have a new new Berlingo it stays on to cool the turbo if short journeys at low speed are detected.
Gravity
Yes i forgot about the regen possibility
Threads: 8
Thanks Given: 297
29
I though in order for a regen to take place certain criteria had to be met, like engine temperature above a certain level and the vehicle travelling above a certain speed for a given time etc.... ?
Threads: 7
Thanks Given: 16
8
(11-12-2017, 11:07 PM)jj9 Wrote: I though in order for a regen to take place certain criteria had to be met, like engine temperature above a certain level and the vehicle travelling above a certain speed for a given time etc.... ?
For a regen to complete its cycle, what you say is correct - things have to get kinda very hot!
But normal engine temperatures can be in place when a regen cycle begins. The dpf state triggers the start, and that's when things begin getting mighty hot.
I lived on a very hot dry island for years, and when cats and dpf's began to be fitted to cars there were many grass fires due to motorists parking on dry grass verges. Warnings were broadcast telling motorists not to park on the grass.
That's progress for you.
Gravity
Today 12:21 PM
Mirrorlink and Android Auto issues
Last Post: djib1946
Today 10:21 AM
Today 07:40 AM
Last Post: Sjbsjb3838
Today 04:22 AM
Yesterday 07:47 PM
Airbag warning light
Last Post: Squad
Yesterday 06:12 PM
Adding heated seats to a k9
Yesterday 05:35 PM
Door Sticker Part number
Last Post: ComboLifer
Yesterday 04:51 PM
2012 MULTISPACE WINDOW REGULATOR FAILURE
Last Post: lauramayer14
Yesterday 04:22 PM
wiper motor replacement
Last Post: mickrochip
Yesterday 02:20 PM
