Vacuum oil change & magnetic sump plug
For my next service, I'm thinking of getting the oil sucked out via the Dip stick rather than the traditional method of the sump plug.
The traditional draining of oil from the sump plug still leaves almost half a pint of old oil in there so the suction method must be certainly better ? or would many here disagree with that assumption ?
I'm also thinking of getting the mechanic to fit a magnetic sump plug to collect any metal debris, and changing that every 3 or 4 services , worthwhile ?
(01-10-2018, 04:55 PM)michaelg Wrote:  I'm also thinking of getting the mechanic to fit a magnetic sump plug to collect any metal debris, and changing that every 3 or 4 services , worthwhile ?
I simply drilled a hole in the original oil screw and glued in a magnet with epoxy.
Attached Files Thumbnail(s)
Regards Rolf
_______
Berlingo Blue HDI120 S&S Shine, 08/2016, KYANOS Blue Metallic
[-] The following 1 user says Thank You to rolf50 for this post:
  • michaelg
Does the magnet collect much ?
I have used a Pela suction pump for years, and would never give a single thought to grubbing underneath and undoing a sump plug.
Park up after a drive and use the Pela immediately. It takes hot oil. Change the filter at the same time. Ignore the doom mongers - You won't get any problems.
And don't bother with fitting an internal sump magnet - just put one on the outside of the sump. It'll do the same job, which is to capture any fine swarf - not that there is much in modern engines.
Gravity
[-] The following 3 users say Thank You to Gravity for this post:
  • michaelg, ron, Wyvern
(01-10-2018, 06:26 PM)Gravity Wrote:  I have used a Pela suction pump for years, and would never give a single thought to grubbing underneath and undoing a sump plug.
I agree.I have a large speaker magnet stuck to my sump.
[-] The following 2 users say Thank You to ron for this post:
  • Art b, michaelg
So a fairly strong magnet then ,,, maybe i'm overthinking but say hypothetically if the magnet came off, you might be left with a lot of swarf floating around.
(01-10-2018, 07:22 PM)michaelg Wrote:  ... if the magnet came off, you might be left with a lot of swarf floating around.
I'd be very surprised if it ever came off - but if it bothers you, then superglue it on.
Modern engines, coupled with modern oils, produce very little harmful metal particles.
Gravity
(01-10-2018, 06:15 PM)michaelg Wrote:  Does the magnet collect much ?
Installed it two month ago the first time. I can tell you next year.
Regards Rolf
_______
If you put a magnet on the outside, how do you clean the swarf off without removing the sump?
There will be  very little swarf but what there is you can move it to the drain plug hole by dragging it  with the outside magnet to the drain plug hole. Use another slim magnet to pull it out.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white  Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
[-] The following 1 user says Thank You to brodfather11 for this post:
  • Art b
Locked car while driving.
Last Post: Desdinova
Today 06:19 PM
Intro / Model
Today 06:17 PM
Today 05:52 PM
Last Post: Oldmaninacampervan
Today 05:17 PM
Last Post: mpj29201
Today 03:56 PM
Air filter box
Last Post: NANO_Vigo
Today 12:51 PM
Today 12:47 PM
Haynes K9 online manual
Today 12:40 PM
Yesterday 09:48 PM
» Replies: 22
Engine occasional hiccup, engine management flas...
Yesterday 08:14 PM
