(11-12-2020, 12:00 AM)boop Wrote: I have three K9 Berlingos. All behave the same way.
Had my Flair D130SS for 18 months, from new (done 10,500 miles)the Stop Start worked for about 2 months and no logic to why.
I bought from Richmond Portsmouth,they could not fix.
In total frustration- I contacted Citroen,UK, made contact with Yeoman's Fareham.
They SORTED it-the re programmer the car, and BOTH keys
The only time it seems now not work is if outside air temperature is very low
The cure is to ensure the battery is 100% charged.
Then LEAVE the car for at least 4 hours for the on board computer to adjust to the new voltage.
I only partly understand the methology, but the Stop Start seems fixed to me, I will update in a month, and 3 months
Roger
6 months on, fix worked for a month, charging after this at 1A took 1- 1 1/2 hours, after leaving over night NO s&s,
HOWEVER out the blue 2 weeks ago in pouring rain,stuck in year in can flat out, lights on all wipers flat out of started working and has worked since.
This seems at odds to the fault primarily being the battery,it's as if MAYBE the low raging nature of this engine is not spinning the engine up enough.
Maybe I am not raging it enough in normal use.
QUESTION- has anyone who has replaced the factory batter because of the fault STILL eventually developed the fault again
