Threads: 15
Thanks Received: 20 in 20 posts
8
Slightly weird but when I turn the engine on I sometimes get a random pop up warning. Sometimes it's too fast to see what it is, sometimes one will stay on - like today it said something like "Fault with either airbag or seat belt tensioner" and the spanner light came on. I switched everything off, got out, locked the doors and left it for five minutes or so.
Tried then again and no warnings at all.
May not be related but if I put the key in the ignition and quickly start up, like you normally do and used to with 'normal' precomputer cars, a pop up seems more likely. Once it misfired on start up and all sorts of warnings came up with the rough engine. Again I did the switch off and leave it for a while then it started normally, no misfire or anything.
If I slowly turn the ignition on (taking about 2 seconds to turn it to the stop), pause and then start it I hardly ever get a pop up, maybe just once.
How do you start up? Key in, turn and start? And no problems?
Now a 2019 K9 1.2 petrol.
Before a 2010 B9 1.6 HDi diesel.
Threads: 75
Thanks Received: 1,281 in 1,134 posts
Thanks Given: 223
162
I turn the key to ignition on, then I wait for all of the extra warning LEDs to go off, then I turn the key to the start position. It seems to start smoothly if I do that, and roughly with a clatter if I just go straight to start without waiting.
______________________
Not a Citroen!
2017 B9 1.6 BlueHDi Van
2012 B9 1.6 HDi Van
2008 M59 1.6 HDi Van
2003 M59 1.9D Van
Threads: 15
8
I'll give that variation a try as well........... thanks,
Threads: 11
Thanks Received: 45 in 43 posts
Thanks Given: 30
7
Have your battery condition checked. Too low voltage at startup can cause all kinds of on-board diagnostic module get ghost readings.
All my other cars regardless the manufacturer have done this when the battery has been weak.
2021 130hp 1.5 BlueHDi EAT8 L2 XTR Gris Platinum
ex: 2003 1.4i cargo
Threads: 11
Thanks Received: 30 in 30 posts
7
I thought all K9s had keyless ignition. Mine has, so don't get the option of waiting for systems to check out before starting. Having said that I think the computer does its own pre-flight checks before operating the starter motor.
Geoff
Threads: 75
Thanks Given: 223
162
04-11-2022, 08:46 AM
(This post was last modified: 04-11-2022, 08:47 AM by Sol.)
(03-11-2022, 06:09 PM)Mark604 Wrote: May not be related but if I put the key in the ignition and quickly start up, like you normally do and used to with 'normal' precomputer cars, a pop up seems more likely.
Looks like Mark has a key.
Not a Citroen!
2012 B9 1.6 HDi Van
2003 M59 1.9D Van
Threads: 15
8
Boop, I'll keep that in mind regarding the battery. Though this last time the stop/start had been working ok and at the time of parking up the engine stopped as I pulled to a stop. I just switched off and get out, so I don't think that was the cause this time. I'd only been out the car for half and hour or so before going back to it.
Guanok, Mine is a November 2019 K9, (Citroën Berlingo Live M Pure Tech 110 M Stop&Start) if it makes a difference, no idea. But it has a key. I bought it in Germany Feb 2020 as what they call a Jahreswagen, we know it simply as a pre-registered car. The list price for a new one with the same specs was high end of 22,000 euros, maybe just into 23,000. Mine had 100km delivery mileage and was advertised at 17,700 Euro.
