  • 7 Vote(s) - 3.14 Average
Horn
I've got horn issues, one minute it won't work the next it's fine. Could it be a bad connection in the steering wheel meaning the air bag has to come out & is it a simple job?
Likely just the horn is broke especially if you have drove thru any big puddles as the get filled with water very easily. All my years of driving i have yet to come across a horn that is faulty at the steering wheel.
It's been like it for ages, apparently berlingos have a problem with the earth connection in the steering wheel
Hmm possibility i have a newer berlingo and im a taxi driver and i've never heard of an earth problem with these, is it the mk2 you have?
Hi Lucialia have a read of this thread it may be of some use http://www.berlingoforum.co.uk/showthrea...light=horn
Are we there yet????? Huh
I'll give it a go I guess, must admit I'm slightly nervous about the airbag....
Make sure you dissconnect the battery and wait 30 minutes before trying to get the airbag off. There are a few threads on here about airbag removal.
If I don't press ours in just the right place it doesn't work every time. I am getting the hang of it now just experiment a bit while you are out of the way somewhere.
(18-09-2013, 08:36 PM)kingy1912 Wrote:  Hmm possibility i have a newer berlingo and im a taxi driver and i've never heard of an earth problem with these, is it the mk2 you have?
Believe me the earth return is about as Mickey Mouse as you can get!
Remove the stupid half-baked clip and use a self-tapping screw and a shake-proof (star) washer.
Well took it all apart today & it is relatively easy, the bottom clip was a bit of a pig but got there in the end. Any all the connectors were solid so no problem there. Any had a new BSI fitted today & now it works fine as does everything else!!!
Rear Suspension Rebuilders?
Today 08:02 PM
Today 07:45 PM
Bolt torque settings
Today 07:21 PM
Today 06:07 PM
Last Post: tdonbay
Today 05:44 PM
Today 03:06 PM
roof rack
Last Post: Vowders
Today 12:33 PM
Today 10:59 AM
Last Post: Wightlingo
Today 07:56 AM
Today 06:51 AM
