Threads: 4
Thanks Given: 4
I have a 1.9d Multispace 2001 which has been converted to a mini camper van and am planning to fit a split charge relay to the leisure battery which is located behind the passenger seat. My question is- where can I run the cable through from the engine compartment? I can see some bunched wires disappearing into the passenger side from the engine compartment but cannot see where they come out inside the car. So far I have removed the glove box and some of the sound proofing, but really do not want to remove the entire fascia. Does anybody have any ideas?
Thanks Given: 188
23
When I needed to run a cable from the battery on my m59 which is basically the same I went from the battery through panel scuttle on the passenger side and then through the bulkhead fairly high up in the footwell. From what I remember under the soundproofing there was a shape of a cut out that the steering column on a left hand drive went through. I drilled through or near to that put a grommet in the hole and ran cable through.
Are we there yet?????
• steve4736
Threads: 7
Thanks Received: 33 in 29 posts
Thanks Given: 5
02-11-2015, 07:38 PM
(This post was last modified: 02-11-2015, 07:42 PM by gazahull.)
hi. i did mine on mk3 thru the bonnet cable into passenger side no drilling............you may need to remove battery to get access.......
Threads: 48
Thanks Given: 4
20
I have also pulled a cable like that. From the battery I went through the rubber around the cable bundle, then down to the floor, removed the metal plate on the doorsill, and threaded the cable under that, then behind the side panel beside the rear passenger seat(Remember, I have the steering wheel on the left side, and there's no rear passenger door on the driver's side) and from there back to the back of the panel on the lefthand side of the trunk.
Threads: 4
Thanks Given: 4
Big thanks for the replies guys! I will have a look and see which solution works.
Threads: 4
Thanks Given: 4
I have had a look and the solution described by Tomcat3 appears to be the obvious one on my vehicle. Thanks!
