problem connecting diagbox to the Berlingo2 2004
Hy Everybody
i am having a nightmare in the last days with diagbox.
I have bought from ebay the PP2000 / Lexia 3 For Citroen Peugeot Diagnostic Tool Diagbox 7.82 963830C/4.3.3V and i have encounter the following problems:
a) first i can only install the updates till 7.74 the others it opens but no interface shown.
b) secondly when i connect the above cable it lights up the green light but no answer from the pc.
c) third i have install the drivers and netframework 3,5
d) the PSA interface checker doesn´t work either means doesn´t find any version
e) i have work with windows xp sp3 and windows 7 32 bits both OS return the same problems.
Presently i have it install in a virtual box and the OS is windows 7 32bits.
Do appreciate your help
I've never tried installing it in a VM. If you plug a normal usb stick into a usb port on the pc/laptop can you see it from the VM?
(31-03-2017, 11:17 AM)3rensho Wrote:  I've never tried installing it in a VM.  If you plug a normal usb stick into a usb port on the pc/laptop can you see it from the VM?
Hy
My friend you are a star : in fact i didn´t see any usb stick or any other ...so i set up for the usb citroen cable e Voilá it works  straight.. Many thanks
Today 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
